rs turbo water and oil mixing
Old Dec 7, 2005 | 07:17 PM
JimmyFlo's Avatar
JimmyFlo
Default rs turbo water and oil mixing
ok guys i put a post up about this a few days back and basically the guy whose looking at my car is asking me tofind out some stuff.
ok so im gettin oil in the water but imgetting no mayo on the dipstick or oil cap, compression is good, oil pressure is good, done over 100miles with no overheating, boost is good and there is no lackof power. and its not using any oil or water. Could it be a crack in the turbo between the oil and waterways? if so would it be ok to bypass the turbo and go s1 style?? i do have a spare turbo but it was a little smokey and then theres the hassle of changing it or could it still be the head gasket?
and just toconfirm that the head gasket is a dodlle on an rs?!?!
Old Dec 7, 2005 | 08:13 PM
davidreader5's Avatar
davidreader5
JIMMY,
you can run the turbo as s1, without damage, is it definitely oil in the
water, or crankcase gase's of the combustion chamber, either way i
would say it is related to the headgasket, as for the water to mix with the oil, if you have a leakage type compression test instead of the normal
comp test, it should put some light on the subject, Yes depending is fairly
easy to do head gasket on the rst.
DAVE R.
Old Dec 7, 2005 | 10:42 PM
RST Ski's Avatar
RST Ski
Bit strange that your not loosing oil, if it is going into the coolant then surely the level on the dipstick will drop because its not returning to the sump, its going else where into the coolant
Old Dec 8, 2005 | 02:16 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
if your head gasket went recently could be residual oil?
Old Dec 8, 2005 | 09:08 AM
JimmyFlo's Avatar
JimmyFlo
the head gasket did go before i bought the car, the head was refaced and the gasket was seated and all head bolts torqued up too. is it fair to swap for a g reg xr2i?
Old Dec 8, 2005 | 11:05 AM
RST Ski's Avatar
RST Ski
wouldnt swap just just yet, does sound like it could be from last time it went. you said u havent had any problems with the running of the car, might bw worth give the bottle and the rad a flush out, stick a garden hose down em, see how you go from there
dont think the xr2i would be as fun!
Old Dec 8, 2005 | 11:25 AM
JimmyFlo's Avatar
JimmyFlo
yeah but i wouldnt be being shady on the bloke swapping with me if the head gasket had gone or anything?? it has a spare turbo and head and ecus so i think imgiving it away really?!?!
Old Dec 8, 2005 | 11:34 AM
vroooom ptssssh
It Wasnt Me!
Yup your giving it away! an average condition 8v XR2i goes for a few hundred quid!!!
i'll give you that for your turbo lol
Old Dec 8, 2005 | 12:20 PM
JimmyFlo's Avatar
JimmyFlo
lol i am getting cash too and the xr is immaculate iv not seenon ein this condition for a long long time
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
cossirob
Aug 29, 2015 03:23 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
Aug 20, 2015 09:21 PM
