My Engine spec oppions please??
My engine spec is as follows
Bluesprint low comp engine
long studed
sleeved block
BD10 cams
T28 hybrid turbo 360 bearing
polished & ported head
bailey breather system
Greens inj
3 bar
msd chip
500 cooler
mongoose exhaust
ram air filter
running 24psi holding 22 psi.
I know it`s a bit pick & mix spec but been told i get even less lag more torque / driveabilty by fitting a standerd cooler,standerd cams,standered air box K&N pannel?
oppions please ??
what improvements can i do??
PS. Don`t want a bigger turbo happy with the gay small one
long studed
sleeved block
BD10 cams
Greens inj
3 bar
msd chip
500 cooler
mongoose exhaust
ram air filter
oppions please ??
i cant see why its not laggy either tbh
seriously drive standard engine cossie with that turbo and tell me what you notice
the amount of air needed for the head and cams would actually eitehr struggle the turbo OR just be slower than it should
I thought i had a standered engine untill the cam belt fell off and we took the engine apart.
fook knows what to do really like the NO lag but it`s a bit over kill with the rest of the spec.
GT28 sounds a good idea though really want to get the most i can out of it with it being laggy
when i had a T3 fitted i though that was laggy
Originally Posted by b19bal
get it R/R test, bet it aint
bound to get another 5 bhp when set up correctly
JoeyBoyden
Jan 4, 2024 02:36 PM
Oct 9, 2015 07:38 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
