Simple Turbo Question
Old Dec 6, 2005 | 07:17 PM
Neil S's Avatar
Neil S
Default Simple Turbo Question
Is it as simple as it looks to swap exhaust housings?
i.e. unbolt the housing and lift it off the core squarely so as not to damage the blades?
Neil.
Old Dec 6, 2005 | 07:56 PM
churchy's Avatar
churchy
From: Out Shooting Burgelers, cause thats what Norfolk people do!!!
I sure do hope so
Old Dec 6, 2005 | 07:58 PM
Rick's Avatar
Rick
compressor housing is easy, exhasut is a twat.
Old Dec 6, 2005 | 08:00 PM
Neil S's Avatar
Neil S
Because you can't remove the bolts fully as they foul the oil feed and water drain, or for some other reason?
Neil.
Old Dec 6, 2005 | 08:30 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
yeah bolts need loosenen till hit core then rotate core till bolts can be fully removed. Core assemblies more or less weld themselves to the ex housing though so dont think it will be easy to split
Old Dec 6, 2005 | 08:32 PM
Rick's Avatar
Rick
Neil.
It's because its so tight - its fused on with the heat. U need to smack it like hell to get it to twist on the core. The bolts will come out - u just need to rotate the core to a position where they will.
Old Dec 6, 2005 | 08:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You can do it but be very careful, a small piece of the flange on the centre core of mine broke off
Soak around the housing in WD40 or something,as mine would not come apart until it had been left for a time.
Turbo still works ok
Steve.
Old Dec 6, 2005 | 08:36 PM
dannyblackpool
Boost Builder
get a lump hammer and smash the fuck out of turbo, it will split then .................. into around 8 peices
Old Dec 6, 2005 | 08:37 PM
Neil S's Avatar
Neil S
Mine is brand spanker, so should come off easy.
Churchy may well be screwed though!!!
Neil.
Rick's Avatar
Rick
lol - if anyone got a 63 housin i need one
Old Dec 6, 2005 | 08:39 PM
Neil S's Avatar
Neil S
Shush, I bagged Churchy's first!
Old Dec 6, 2005 | 08:40 PM
Neil S's Avatar
Neil S
PS, there's a .63 on Fleabay presently:
http://cgi.ebay.co.uk/new-cosworth-6...QQcmdZViewItem
Neil.
Old Dec 6, 2005 | 08:44 PM
RichardPON's Avatar
RichardPON
Mine was real easy - boxed it and sent it to Universal Turbos!
Old Dec 6, 2005 | 09:23 PM
churchy's Avatar
churchy
That is purly because your head resembles a testicle
I'll be fine, may apply some heat first to loosen it all up Then treat it to a shit load of WD40, then get ole sledgy on the task
Matt Baxter
Sep 16, 2015 08:30 PM
Marcus L
Aug 29, 2015 02:18 PM
borboyous
Aug 22, 2015 11:17 AM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
