help with wandering.......
Old Dec 6, 2005 | 04:12 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
Default help with wandering.......
the 306 is wandering like fook! , changed the drivers track rod end for mot and passenger ball joint as failed,wandering went but now come back worse than ever, but only does it under acceleration in 3rd,4th,5th. 1st and 2nd fine but soon as in 3rd and accelerate wanders right quite hard and you need to turn into it,back off and it moves back left, any ideas? since changed other track rod end also,tracking ok but not had chance to look since
Old Dec 6, 2005 | 04:22 PM
TIFF's Avatar
TIFF
Chasing Radders
Rear beam
Old Dec 6, 2005 | 04:23 PM
dannyblackpool
Boost Builder
expand on that tiff, thinking about it the drivers rear wheel has started rubbing on hard cornering
Old Dec 6, 2005 | 04:26 PM
TIFF's Avatar
TIFF
Chasing Radders
If the bearings and seals have gone on the rear beam it will need rebuilding.......
Check by jacking the rear up and checking the play in the wheel, much like you are checking wheel bearings..This will show if the beam is fooked.
But if you say the rear wheel is rubbing on hard cornering i would say it may well be that
Old Dec 6, 2005 | 04:30 PM
dannyblackpool
Boost Builder
Cheers m8
Old Dec 6, 2005 | 04:36 PM
TIFF's Avatar
TIFF
Chasing Radders
I have just had the rear beam on the 205 rebuilt because of just that problem mate......
Old Dec 6, 2005 | 04:49 PM
dannyblackpool
Boost Builder
hmmmmmmm just been out and had a feel and BOTH rear tyres are only a few mm from inner arch at top Deffo mbeam looks like,not jacked up yet though
Old Dec 6, 2005 | 04:51 PM
TIFF's Avatar
TIFF
Chasing Radders
Hopefully the rear beam tube is ok to reuse as there are some bearings inside that cant be taken out......if thats shot you better get hunting for a rear beam tube
Old Dec 6, 2005 | 04:53 PM
dannyblackpool
Boost Builder
is it summit i can sort?? ie mechanically minded or is it a pro job??
Old Dec 6, 2005 | 04:55 PM
TIFF's Avatar
TIFF
Chasing Radders
You may be able to do it yourself but it is a fucking pain in the arse, i know most people dont try it themselves....
I just paid someone to do it as i know it is 100% spot on then
Old Dec 6, 2005 | 04:57 PM
dannyblackpool
Boost Builder
problem is missis needs it to travel to work daily which is 30 mile and aint got another car (or road legal one) so in the shit really
Old Dec 6, 2005 | 04:59 PM
TIFF's Avatar
TIFF
Chasing Radders
HHmmmmmmmmmmmmmmmmmm
You could keep your eye out for a rear end from a 306 as it is not cheap to rebuild them
That is IF it is the problem.........but i does sound like it
Old Dec 6, 2005 | 08:34 PM
dannyblackpool
Boost Builder
Had a look and I THINK the beam is ok Cant see much but jacked up in the street and NO play on either wheel so praying just shit offset wheels that need a spacer, Jacked the front and both of the rear bushes on the front control arms have split
Fix for under a tenner though so hoping thats all it
Old Dec 6, 2005 | 08:43 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Which 306 is it mate??? It could be your rear subframe bushes that have gone....do you get like a loud banging from the arse end if you brake heavily???
My 17s where VERY close to the arch & did occasionally catch especially when I lowered it.....so I got the grinder out which helped a bit - they were the correct offset as well!!!
Old Dec 6, 2005 | 09:59 PM
dannyblackpool
Boost Builder
std 306dt on a 96 p plate, std ride height with std size 185.60.14 alloys although they aint the dt alloys but are genuine pug ones,no banging under hard braking no
Old Dec 6, 2005 | 10:20 PM
Lee_R21Turbo
How many miles has she done mate???
Old Dec 7, 2005 | 10:00 PM
dannyblackpool
Boost Builder
Old Dec 7, 2005 | 10:03 PM
TIFF's Avatar
TIFF
Chasing Radders
Originally Posted by Danny@RADesigns
206,000
Old Dec 8, 2005 | 07:27 AM
Lee_R21Turbo
206,000
Jesus wept!!! Even if the rear bushes have been changed once in its life....its time to do them again...and if they aint well.....no bloody wonder its wandering!!!
Old Dec 8, 2005 | 04:30 PM
dannyblackpool
Boost Builder
looking for play though jacked up surely there aint none,gonna change control arm rear bushes 1st as deffo gone then go from there
Whats wrong with 206,000
Old Dec 26, 2005 | 11:04 AM
dannyblackpool
Boost Builder
update
Right wandering was control arm rear bushes fooked,changed and now mint but back to the rear beam.................
Still catching on drivers rear so took a gander, Wheel seems cambered in to much and catching arch liner so removed over xmas as killing tyre. There is no banging etc and drives perfect now and no play when jacked up
Thought maybe was just bad offset wheels so dug some spacers out of garage and whacked em on, FOOK ME she bangs now under braking,the whole back end jumps around and it feels as though the cars about to split in 2!! Still not actually jacked upand got under with a light but are beam bushes/mounts the 1st call of inspection then?? if the beam bearings are fooked surely there will be play. Any other ideas ppl
Old Dec 26, 2005 | 11:07 AM
TIFF's Avatar
TIFF
Chasing Radders
To me it DEFFO sounds like a rear beam issue
Why not try this........i know it may go against everything you know Danny but..................
Jack it up and get underneath with a light
Old Dec 26, 2005 | 11:14 AM
andre_k's Avatar
andre_k
206,000
fook me!!!
Old Dec 26, 2005 | 11:22 AM
dannyblackpool
Boost Builder
Tiff......................... its boxing day
might look tmoz
then again mite not
Ps its 208,400 not 206,000
