HELLLLLLLLLPPPPPPP !!!!, need tech advice !!!!
Old Dec 5, 2005 | 08:23 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default HELLLLLLLLLPPPPPPP !!!!, need tech advice !!!!
i CAN NOT for the fucking life of me remove my fucking bottom pully from my engine, ive EVEN dented my fucking MINT tennis cabrio wing in the fucking process
need some advice as its fucking tight on there, seriously tight
does WD40 or anything better REALLY work, its fucking tight though and ive got a huge 3/4 ins breaker bar and thats bending and the engines just moving all over the place, last attempt the engine slipped to the side and put a fucking huges dent in the wing
SERIOUS advice needed
Old Dec 5, 2005 | 08:31 PM
croppy's Avatar
croppy
can u get air supply 2 it windy gun the bastard off
prob only way if that tight mate
Old Dec 5, 2005 | 08:35 PM
Ginge !'s Avatar
Ginge !
cant do that and its REALLY on tight, ive got a breaker bar the length of my leg and all ive been doing is moving the engine about, does WD40 really work or am i just fucked
Rick's Avatar
Rick
puller? id drop the engine out.
Old Dec 5, 2005 | 08:38 PM
Ginge !'s Avatar
Ginge !
its no where near the car, its on a stand and its not fucking budging the only car its near is a escort cabrio and its just fucked my fucking paint job and orginal wing
any otherway to get the cam belt off, the pully for the dizzy cant come off either as the bottom pully is in the way
Old Dec 5, 2005 | 08:39 PM
Rick's Avatar
Rick
defo need a puller then!
Cowboi's Avatar
Cowboi
oh ginge, ginge ginge.
have u done what i did with ur cossie one? used a bit of rope to keep the pully still?
best way to do it is to shock it.
big hammer, solid bar and give it a few wacks.
any movement is good movement, so even if u can do it up a bit it will break the seal it has and then it should undo.
the wd40 will help if u can get it into the thread. but sounds like its pretty tight so it might not work to great tbh.
stick it in gear as well, it will give it some resistance to help u undo it.
Old Dec 5, 2005 | 08:42 PM
Cowboi's Avatar
Cowboi
is the sprocket for the cam belt and the pully all one unit?
after spending hours getting my bolt out of my crack i found out that the outer pully actually un bolts from the sprocket and when u take the tension off the belt u can take it off the sprocket. all with out removing the bastard bolt!
to do mine i used a propane portable blow tourch, bar and club hammer. in the end it went
Old Dec 5, 2005 | 08:43 PM
croppy's Avatar
croppy
stick the car in gear and foot on the brake to keep pulley still to undo
then a puller to remove pulley
RichardPON's Avatar
RichardPON
Ginge - I had exactly the same with mine.
I tried "shocking" it to, but ended up breaking the bastard
In the end, I used a puller I had, and it eventually came off............... four hours later
Old Dec 5, 2005 | 08:44 PM
rsnissan's Avatar
rsnissan
heat or a puller get on msn
MoonDustSaph's Avatar
MoonDustSaph
What can't you get out? the centre crank pulley retaining bolt or the pulley itself?
Old Dec 5, 2005 | 08:45 PM
Cowboi's Avatar
Cowboi
i was just thinking the same thing.
Old Dec 5, 2005 | 08:46 PM
St3V3_C's Avatar
St3V3_C
RichardPON, just been looking for this...
B19 - this post goes a bit OT, but there is a bit of good advice too.
https://passionford.com/forum/viewtopic.php?t=137478
Are we talking the bolt or the pulley
seveneigths's Avatar
seveneigths
Take your intercooler and radiator out and then you can use a air gun and then use pullars, thats the easiest way imo
Thats the way i was shown, i hope that help mate
Old Dec 5, 2005 | 08:48 PM
kevandalice's Avatar
kevandalice
how can it be put in gear if its not in the car?
Ginge !'s Avatar
Ginge !
i got a puller,,,,,,, thats not the issue YET though, i cant get the poxy twatting bolt off
ivetried shocking, shouting spitting and even calling its mum a slag, IT AINT COMMING OFF , anymore force and im gonna sheer the bolt
btw the car is in gear ,,,,,,,, just thats 3 miles from where the engine is and so i dont feel that helping much
Old Dec 5, 2005 | 08:51 PM
Ginge !'s Avatar
Ginge !
mate this is a normal garage not the ferrari pit lane
the intercooler is in the bathroom and the rad is in my little girls room but i dont have air tools
cheers though
its the poxy bolt btw
Old Dec 5, 2005 | 08:53 PM
MoonDustSaph
Without being able to apply heat then you are back to wacking it with a hammer. You need to some how prevent the crank turning at the same time tho. What state of build is the engine in?
Old Dec 5, 2005 | 08:54 PM
PAUL V's Avatar
PAUL V
if the fly wheel is on put a old screw driver though 1 of the gear box mounting bolts and jam the flywheel up.
Old Dec 5, 2005 | 08:55 PM
Ginge !'s Avatar
Ginge !
this engine has no cams in it and ive also fractured my missus wrist when the first 24 mil socket snapped and i hit her wrist with the hammer
hence the late reply, i finished work at 5 to start this
Old Dec 5, 2005 | 08:57 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Disclaimer !
Try this at your peril !
BUT IT WORKS FOR ME
Get a good quality ring spanner or solid bar (not a ratchet handle) on crank bolt - make sure it if on bolt 100%
Put a piece of wood between spanner/bar and chassis rail to stop the spanner turning or put spanner/bar against floor
Disconnect coil - Remove spark plugs
Get a trusted friend to "flick" ignition key on and off
The torque a starter motor produces is usually enough to do the job
Ensure you have spanner/bar trapped the right way to undo as well
Watch fingers eyes etc for flying spanners though
Ginge !'s Avatar
Ginge !
theres no way tpo to that, ive checked seriously looked and also the hammer is out the question, missus wants it done big time though now
Old Dec 5, 2005 | 08:58 PM
croppy's Avatar
croppy
if the engines out how the fook can he damage the wing pmsl laughing @ kev
PAUL V's Avatar
PAUL V
Originally Posted by RS2000CUSTOM
Disclaimer !
BUT IT WORKS FOR ME
Done that my self dave, but the engine is not in the car
scruffythefirst's Avatar
scruffythefirst
Get two scaffold tubes at least 4 feet long, use one to hold the engine stand still and slide the other right over the breaker bar, so it wont bend then slowly increase the pressure but do it gently otherwise you'll slip.
Old Dec 5, 2005 | 08:59 PM
Ginge !'s Avatar
Ginge !
Disclaimer !
BUT IT WORKS FOR ME
FUCK THAT !!!!!
ive just totally resprayed my engine bay and even if the engine was in i would NEVER try that
Old Dec 5, 2005 | 09:00 PM
MoonDustSaph
How about fitting 2 bolts in the flywheel where the clutch mounts lay a bar through so that it pitches on the ground and then fit a socket on the front bolt and hit it sharply with a copper hammer on your breaker bar.
Or as suggested jam a screwdriver in the starter ring, but thats more a 2 man job.
Old Dec 5, 2005 | 09:02 PM
kevandalice
err... because he hit the wing of another car parked nearby.
if you read the posts it tells you
Old Dec 5, 2005 | 09:03 PM
Ginge !'s Avatar
Ginge !
Disclaimer !
BUT IT WORKS FOR ME
the wing i dented is from my pride and joy that i love soo much ive stored in the garage the cossie engine was located in there temp and beside the car of my dreams
RS2000CUSTOM
Missed that bit - lol lol
Take it to a truck tyre fitting bay and let them use a truck wheel nut air gun
Even if crank spins those air guns generate a shit load of torque - should do it !
Old Dec 5, 2005 | 09:04 PM
foreigneRS's Avatar
foreigneRS
Testing the future
bolt needs shocking ginge.
get yourself a Ł20 12V electrical wheel nut gun and it'll have it open in no time.
i also saw a mental thing in a tool catalogue the other day that you put into a socket and you twat a bar thing with a hammer and it converts it into a rotational shock. have no idea where i saw it, or what it was called though
Old Dec 5, 2005 | 09:06 PM
GUZZLER's Avatar
GUZZLER
if the engines in bits then put a wooden hammer shaft on the crank to lock it in place, get your wretched skinney arse outta the way & get someone with a bit of beef on the bar & someone with a bit more beef holding the engine!!!
failing this, fire the block in a car, take it to work & get someone to airgun the bolt off
Ginge !'s Avatar
Ginge !
fook me you dont do things by halfs
i live in central london so there no truck bays near here, infact all the arches are clothes shops now
is there another way to change the cambelt leaving it on as i supose good news is its not comming off
Old Dec 5, 2005 | 09:08 PM
Cowboi's Avatar
Cowboi
ginge, read carefully.
get some rope, start at the bottom of the pully, rap cloackwise round the pully 1 and 1/2 turns so that it goes all the way round and back over the begining of the rope. then it comes off the top of the pully to the right.
find a bracket or something solid on that side of the engine.
now when u turn the bolt anticlockwise the rope should tighten up on itself. this will stop the pully from moving and therefore the crank.
now u should be able to put ur socket on it and apply as much pressure as needed till it goes.
now i did this and snapped the rope twice, then i got another bit or rope and the blow tourch, and that time it went.
shocking it like that will help more then as well as the rope will increase the amount of force from the hammer get transfered to the bolt.
if u know what i mean.
rsnissan's Avatar
rsnissan
do you mean an impact driver ?
GUZZLER's Avatar
GUZZLER
Ginge, you cab slip the belt off & slip the new one in, but its good knowing that your struggling
Old Dec 5, 2005 | 09:10 PM
GUZZLER's Avatar
GUZZLER
i had one of them when i was young, they work though
Ginge !'s Avatar
Ginge !
engines not stripped, just this fucking bolt
im seriously loosing the will to live as ive not only hurt the one i love ive also clubed my missus with a hammer
ive got a huge fucking breaker bar, it aint budgeing, i need to foind a way to lock the flywheel really tight i think and find the best version of WD40 they ever made
UNLESS theres anotehr way to change the cam belt and not take the pull off
RS2000CUSTOM
Carefully cut new belt across its width
Feed onto bottom crank pulley
Sew belt back together
Problem solved
I wouldnt run engine though ! - lol lol
Keep at it though it will undo in the end
