does an x reg ford ka have a code in the key?
as above. can it be started without the key. my friend has lost her keys and (i can replace the barrell) it needs moving quick! any help appreciated
so new locks all round then eh!. if i have a key code (which is prob in the documents) can i get a blank key and code it, break the lock and get it moving do you think. as i am awear the ignition reads the keys so it should be possible?
she not going to be happy lol
Your best bet is to by a new lock set costs around Ł60/70 and comes with all new locks and keys.
As you will need 3 keys cost Ł20+ each if you have to key number.
fit the locks yourself then you have to get it programmed
i A ford dealer will charge about an hours labour just to progamme and you have to tow it there a cheaper option is to call out a moblie auto elec as this would be cheaper
borboyous
Aug 22, 2015 11:17 AM
