EFI and Cossie Management
Nov 30, 2005 | 06:14 PM
do u have to go EFI (same as fiesta turbo) b4 getting cossie management or is it all the same shit in a kinda way?
or am i just talking shit
Nov 30, 2005 | 06:26 PM
Re: EFI and Cossie Management
Quote:
Correct!
2 different types of system. Fit one OR the other. Pointless going to one type to then remove it to fit another.
Nov 30, 2005 | 06:30 PM
cheeRS
so what do i need to fit cossie management. could i do it myself?
Nov 30, 2005 | 09:00 PM
cue jano oddkid....
Nov 30, 2005 | 10:27 PM
cheeRS
These should keep you busy....
Loom Cosworth 2wd
ECU Cosworth 2wd
Throttle Body Cosworth 2wd / 4x4
Idle Valve Cosworth 2wd / 4x4
Ignition Amplifier + Heat Soak 2wd / 4x4
Crank Sensor Cos (Now Phase Sensor) 2wd / 4x4
Throttle Position Switch Cosworth 2wd / 4x4
Fuel Regulator Cosworth 4x4
Water Temperature Sensor Cosworth 2wd / 4x4
Charge Air Temp Sensor Cosworth 2wd / 4x4
Injectors STD Cosworth 2wd / 4x4
Map Sensor 3Bar
Nov 30, 2005 | 11:06 PM
Click the sig for info on "how to"
Regards
Jano
Nov 30, 2005 | 11:15 PM
thank you
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
