FAO: Tiff.....when bleeding radiators......
Old Nov 27, 2005 | 12:08 PM
Disabled Account's Avatar
Disabled Account
Default FAO: Tiff.....when bleeding radiators......
Do you start with the one thats closest to the boiler.......or the one that is furtherist away????
Old Nov 27, 2005 | 12:09 PM
Ginge !'s Avatar
Ginge !
just finding my feet
i would start at the closest BUT thats just me guessing
Old Nov 27, 2005 | 12:19 PM
Katie's Avatar
Katie
probably best guesstimate is start with the one furthest away then
Old Nov 27, 2005 | 12:21 PM
I dont see why it makes any difference?
surely all the air is at the top of the radiator, and not anywhere near the coolant flow along the bottom, so its not going to make its way from one to the other anyway?
* Disclaimer, i know nothing about houses pretty much, its purely a guess, please ignore me *
Old Nov 27, 2005 | 12:23 PM
Ginge !'s Avatar
Ginge !
i was thinking that the air lock may cause the water not to flow as well, get rid of the air lock as close as poss would help the water to flow more freeer and make the rads air lock on the others quicker
oh and for the record i have NEVER needed to bleed a rad in my life, ive had a new boiler ect last year but they never needed rebled , does this mean it might be worth while
TIFF's Avatar
TIFF
Chasing Radders
I always do the ones furthest from the boiler first, and work back
Old Nov 27, 2005 | 12:24 PM
Katie's Avatar
Katie
result....go me
Old Nov 27, 2005 | 12:26 PM
Dunccoss's Avatar
Dunccoss
does not matter that much but
turn off boiler and pump.
if 2 floors do ground floor first.
Leave heating on at max on boiler for about 2 hours ( you do this because when the water temp in the rads get to 65 the air in the water will seperate and gather in the top of your rads again )and then switch off including pump and go round and re bleed rads.
then switch back on and set boiler and programmer back to your normall settings
If you follow that you should be ok
Disabled Account
Thanks Tiff.......will give it a try now
Old Nov 27, 2005 | 12:28 PM
TIFF's Avatar
TIFF
Chasing Radders
Also as Dunc says, get it up to temp and turn it off so the pump isnt running
Old Nov 27, 2005 | 12:29 PM
Just noticed I referred to the water in the system as "coolant" in my post.
Definately too car focussed
Old Nov 27, 2005 | 12:30 PM
Disabled Account
OK, thanks for that detailed reply too Duncccoss.........I will follow that through to the letter, as every time I bleed the system (so far) within a week or so the furtherist away rad ends up cold at the top (but nice'n'hot at the bottom).......all the others are fine!
TIFF's Avatar
TIFF
Chasing Radders
I assume the Flue is the Exhaust then
Old Nov 27, 2005 | 12:35 PM
Ive got a K&N cone filter on my boiler
Old Nov 27, 2005 | 12:46 PM
Dunccoss's Avatar
Dunccoss
doug if you are having to bleed the system every week then you have a problem, after you bleed them this time
try turning the pump down to a lower setting ( this if on the pump and if new will be from 1 to 3 )most people leave on 3 but this can cause problems on older systems as the new pumps are stronger than the old one it replaced and can pump water in to your expanshion tank in the loft doing this brings fresh water down in to your heating system and with that also air which ends up in your rads, so if you can turn pump down a setting and try that as long as all your rads get warm the pump will be fine set at this.
ps have you got an old system ?
Old Nov 27, 2005 | 12:51 PM
Disabled Account
No, this is a 4 year old system in the workshop/garage. Actually oil fired (Worcester/Bosch boiler). The place is 2000 square feet and I'm using 4 x large rads - each one is 10 ft (3 metres) long and 28" high.
Old Nov 27, 2005 | 12:56 PM
Dunccoss's Avatar
Dunccoss
doug is it a sealed system because if it is forget what i said in my post above
Old Nov 27, 2005 | 01:02 PM
Disabled Account
No it has a black plastic tank that is issulated (approx 18" wide x 15" high x 12" front to back) The tank has no water supply too it because I did not want mains water in the roof space, so I top up/check level of the tank at least twice a year. It normally needs about couple of litres of topping up per year thats all. No leaks anywhere it's just evaoration I'm 98% sure.
Old Nov 27, 2005 | 01:07 PM
Dunccoss's Avatar
Dunccoss
well doug just turn the pump down one on the boiler you might find that helps and as far as the tank i would say its evaration as well just make shure the tank is about half full and check the temp and level in the tank once the heating has been one for about 2 hours, if the water is hot then you have found your problem
Old Nov 27, 2005 | 01:27 PM
Disabled Account
OK, it's a "Grundfos" "selectric" pump (red/pink hamerire paint finnish), I've just turned it to the middle setting.....
Chas
Oct 5, 2015 07:13 PM
kevin36
Sep 9, 2015 11:12 AM
markk
Sep 9, 2015 08:11 AM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
