P8 with Dizzyless?
Old Nov 26, 2005 | 11:17 PM
polly_x's Avatar
polly_x
Default P8 with Dizzyless?
Anyone confirm what I believe should be the wiring for the Rev counter on a P8 with ALS Pectel board?
Is PIN 21 the rev counter output and can it be switched on and off in the program?
I have a VDO tacho that worked fine off the distributor. Cars now runs dizzyless but cant get a rev count signal?
Cheers,
Old Nov 27, 2005 | 04:41 AM
Stu @ M Developments's Avatar
PassionFords Creator
Your output speed has been halved. Your mapper would have known this and should suely have told you?
Is the Tacho adjustable? If so, set it to DIS.
Mar 11, 2008 09:23 PM
jacko996
Nov 25, 2007 10:02 PM
Moonstone Mart
Oct 1, 2007 06:18 PM
polly_x
Nov 27, 2005 01:15 PM
