Coolant
Old Nov 26, 2005 | 03:07 PM
ballin's Avatar
ballin
Default Coolant
Does anyone else's FRST do this?!
When the engine is running coolant level is MAX or just over, but after you switch off it ALL drains out of the header tank.
Turn it on again and it back fills from the bottom again!
Should I be filling it after its drained back in, but then when engine is running its going to be well over MAX?
bit confused
Old Nov 26, 2005 | 05:00 PM
jrs's Avatar
jrs
Mine when it's low and cold then warmed up it appear's and go's to max level
Old Nov 26, 2005 | 09:46 PM
ballin's Avatar
ballin
strange one, think im gonna fill mine to MIN once its cold and all drained away - not sure if thats right or not but hey ho
Old Dec 5, 2005 | 04:15 PM
s2_rsturbo's Avatar
s2_rsturbo
i had this problem. turned out to be a hole in head gasket
Old Dec 5, 2005 | 06:41 PM
ballin's Avatar
ballin
lol nice :P
if it was loosing it fair enough could be, but it keeps coming back...from where i dont know tho
Old Dec 5, 2005 | 09:45 PM
s2_rsturbo's Avatar
s2_rsturbo
i had same problem. no water then when i fill it up and start it up again it overflows. maybe your water pump on the way out!
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Chas
Oct 5, 2015 07:13 PM
Botts
Sep 22, 2015 02:04 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
