What power do you think???
Going to build up my engine again, once my shell is sorted so i can drive it about, Thinking of this spec for a time being...
Standard head/bottom end
De-Comp plate
Cossie management/L8/803's
T34
Mongoose
2x 4x4 intercoolers welded together
20psi...
Radleigh
De-Comp plate
T34
Mongoose
20psi...
Radleigh
De-Comp plate
T34
Mongoose
20psi...
Radleigh
De-Comp plate
T34
Mongoose
20psi...
Radleigh
youll need arp rod bolts
vulcan done mine about 9yrs ago and still going strong(i got bigger valves/porting done while it was there)youll get a few people staying away from the place but the service and reliability from there i can only recommend them
If the head work is anything like mine, then 20psi on a T34 (what exhaust housing?) could be around 250bhp.
I'd get some steel rods mate, and I wouldn't use Vulcan again if they were the last engine builders on Earth. I would rather build my own intergallactic ship and search other solar systems looking for some half monkey, half slug type aliens that would do a better job than those bunch of CU_NTS!!!
Oh, and good luck with the build by the way
De-Comp plate
T34
Mongoose
20psi...
Radleigh
De-Comp plate
T34
Mongoose
20psi...
Radleigh
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
deathrider666
Sep 28, 2015 06:12 PM
