popping flames
Old Nov 24, 2005 | 08:15 PM
kiddie's Avatar
kiddie
Default popping flames
Got a flamer kit, filled up on tesco's super unleaded 99 and its been popping flames all over the place! Just wondered how you can make it flame just by reving? Done it once, just wondered if there was a certain way other than just reving it up hard? Seen an RS run a constant flame once just by keeping the revs @ 2k???
Old Nov 24, 2005 | 08:22 PM
stusfesta's Avatar
stusfesta
ahhhhh sweeeeeet. im gonna put mine on at weekend. did u weld spark plug in or weld a nut in?
sorry cant answer ya question......yet
Old Nov 24, 2005 | 08:40 PM
Leggetts 4x4 Cossie's Avatar
Leggetts 4x4 Cossie
Best results is to get the car warm first, once its warm, you can rev away.
They should not hold flames, unless your running far to rich.
Old Nov 25, 2005 | 03:28 PM
kiddie's Avatar
kiddie
any other hints?
Old Nov 25, 2005 | 08:06 PM
rsturbo90's Avatar
rsturbo90
go cossie management and run light blues like mine lol gets lots of fuel going through and really good flames!! you cant really have constant flames, when engine is warm just rev on spot then let off accelerator and you get them, like mine in the pic
Old Nov 26, 2005 | 08:50 AM
russel7.wanadoo.co.uk@fs's Avatar
when you rev hard then let the revs come down to idle thats when the air gets sucked back up the tail pipe makeing a combustion mix = flames (correct me if im wrong)
so if you ad some sort of air suply into the tail pipe(like compressed air) you should get a flame at high revs also
Old Nov 26, 2005 | 04:24 PM
stusfesta's Avatar
stusfesta
ive put my flamer kit on today and it wont flame! lol the spark is fine it just wont light them? any ideas?
Old Nov 26, 2005 | 04:50 PM
kiddie's Avatar
kiddie
what boost ru running?
Old Nov 26, 2005 | 04:51 PM
stusfesta's Avatar
stusfesta
standard mate
Old Nov 26, 2005 | 04:59 PM
kiddie's Avatar
kiddie
that could be the reason? mines 25psi and does it best with tesco super 99
Old Nov 26, 2005 | 05:02 PM
Oranoco's Avatar
Oranoco
25psi on mine with a5th injector. Once warm it flames like a bitch. Completely pointles the flamer kit but it still makes me grin like I'm 10 again
Old Nov 26, 2005 | 05:06 PM
kiddie's Avatar
kiddie
Ditto Got a 5th injector on mine aswell. How do you pop flames by reving? Just blip the throttle or really rev it up
Old Nov 26, 2005 | 05:22 PM
Oranoco's Avatar
Oranoco
TBH I've never tried to make it flame at standstill.
Old Nov 26, 2005 | 06:20 PM
JayRS2000's Avatar
JayRS2000
ive got a falmer but it was on there when i got the car
so how do u guys do it then >???
when i push the button it seems to affect the cars revs drops to bottom and stalls ??? im lost
does the engine have to be warm ? and best revs to do it at
the dude i got it off did say but it was awhile back plz help big crews soon wanna get it out lol
Old Nov 26, 2005 | 07:51 PM
zippyobrien's Avatar
zippyobrien
i was undr the impression that you were supposed to have a swith on the flamer,
when you flick the swith the feed to the coil is cut and thus floods the engine, the spark in the tail pipe then lights the flames.
also if you driving along and put your foot down, if you turn the ignition of as you come on boost youl get a massive back fire and big flames (you dont actually need a flammer to do it this way)
i want a proper flamer now!!!!!!!!!!!!!!1
Old Nov 26, 2005 | 08:52 PM
Oranoco's Avatar
Oranoco
The flamer kit I have (as fitted by SCC) has a sparkplug in the tail pipe and a coil. It relies on the natural unburnt fuel present upon lifting of the accelerator not cutting power to the normal running coil. Turning the ignition off as you come onto boost is a sure fire way to fuck something (probably expensive) pretty quickly.
Old Nov 26, 2005 | 10:27 PM
i have to give it some boost down the road then push clutch in and let the revs come all the way down to get a good flame
i cant get it to flame very often just reving
turning off the ignition turns off the fuel pump also, so you need a switch just on the coil
Old Nov 26, 2005 | 10:36 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
i aint gotta flamer kit but mine popped a few flames when i hit the limiter
6600rpm
Old Nov 27, 2005 | 08:31 AM
stusfesta's Avatar
stusfesta
surely i should still have enough petrol coming through to flame? it is chipped but i know the engine is running a bit lean but dont know how to adjust it slightly??
please help as i feel left out now!
Old Nov 27, 2005 | 09:37 AM
kiddie's Avatar
kiddie
You don't wanna be doing it like that m8!
I can drive with my flamer switched on, all it does is starts the sparkplug in the exhaust working like Oranoco's.
Got a couple of huge ones last night as I hit the limiter in 2nd!
Old Nov 27, 2005 | 10:11 AM
stusfesta's Avatar
stusfesta
oh hang on, do you lot have the plug sparking all the time and it just flames when it wants to? on mine ive got a switch where it doesnt stay on, u just press it wen you want it to spark then let go of the switch and it turns off. shall i change the switch so i can leave it on the whole time that im driving?
Old Nov 27, 2005 | 10:12 AM
James Raby's Avatar
James Raby
It's also where in the rev range and how you control the boost to how well it actually flames
I think I've mastered it now
Old Nov 27, 2005 | 02:01 PM
zippyobrien
isnt the ignition cut at 6200rpm and the feul at 6500rpm
this is the reason you get big flames as you hit the limiter.....
Old Nov 27, 2005 | 03:07 PM
James Raby's Avatar
James Raby
You what - never heard anything so silly
Old Nov 27, 2005 | 03:14 PM
RS_JAY's Avatar
RS_JAY
I had one when it cuts the coil and it worked fine. Never would do it on boost though!
Old Nov 27, 2005 | 03:59 PM
kiddie's Avatar
kiddie
Old Nov 27, 2005 | 09:12 PM
zippyobrien
if you look in the technical information for an rs turbo (haynes manual or even the hand book) it states that the car has a two stage rev limiter with either the fuel or ignition (cant remember whether its the fuel or ignition which is cut first) being cut at 6200rpm and the second one of the two being cut at 6500rpm.
if it was the ignition which is cut first, the engine wouldnt be burning any fuel between 6200rpm and 6500rpm hence all the fuel goes into the exhaust and you get big flames.
Old Nov 28, 2005 | 05:44 PM
stusfesta's Avatar
stusfesta
blimey you lot are gettin technical now!
im getting flames now! really big when im going up the box between gears! when do you lot get the flames mostly?
Old Nov 28, 2005 | 05:55 PM
Oranoco's Avatar
Oranoco
Mine flames at it's best once in 3rd or higher. Bring it up onto boost and lift off. Flames. Got a short clip on my PC of mine flaming when I first got the kit but don't know how to post it
Old Nov 28, 2005 | 05:57 PM
stusfesta's Avatar
stusfesta
LOL i aint got a clue either! ok ile try doing that
Old Nov 28, 2005 | 06:03 PM
Oranoco's Avatar
Oranoco
My bro's FRST after a nice thrash.
Old Nov 28, 2005 | 06:16 PM
stusfesta's Avatar
stusfesta
nice! is there anyway i can make my car flame better? been told about moving the throttle position and done that
Old Nov 28, 2005 | 06:27 PM
Oranoco's Avatar
Oranoco
Seems to differ from car to car TBH.
Old Nov 28, 2005 | 06:34 PM
SamERST's Avatar
SamERST
Oranoco how much was your kit fitted, and where abouts is the place that done it ?
Old Nov 28, 2005 | 08:00 PM
Oranoco's Avatar
Oranoco
£150 supplied and fitted.
SCC Perfomance
London Road
St Albans
Herts
01727 867747
Old Nov 28, 2005 | 08:06 PM
SamERST's Avatar
SamERST
Cheers bud i might just have to pop down there
IainRS1700T
Sep 25, 2015 06:44 AM
rog
Sep 16, 2015 03:00 PM
Iain Mac
Sep 13, 2015 09:16 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
