how hard to remove and refit coreplugs on a s2
Old Jul 10, 2004 | 08:11 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
Default how hard to remove and refit coreplugs on a s2
as above . will i encounter any problems doing this
thanks dave
Old Jul 10, 2004 | 08:22 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Not amazingly hard. Depends on access really. A hook type tool will help. Just make a hole in it and pull it out. Emery the edges on the engine to get them as clean as poss. Then put some "blue" on the new plug. Get a socket thats EXACTLY the same size and hit that to GENTLY drive it into the block.
HTH
Old Jul 10, 2004 | 08:43 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
its the front ones . im going to remove the manifold and what you have said will realy help, im going to change them all while im there, but havent changed any before, one has started to leak, ive been told its due to the engine having no coolant in it for 10 months recently, ???????
cheers rich.
IainRS1700T
Sep 25, 2015 06:44 AM
Fudgey
Sep 17, 2015 01:06 PM
Si B
Sep 12, 2015 06:49 AM
hopper350
Sep 4, 2015 12:53 AM
