desperatley needed help
I need any info you can give me.
i have a series2 erst, fuel relay blew 3wks ago. So while i was waiting a replacement i put a stage 2 head on the car.
Got the relay but the pump wont come on.......i got another feul relay but again the pump wont kick in.
if i bypass the relay the pump works fine........how can i solve this problem?? would it be down to the loom in anyway? as that had water on from a small hole below the front screen (repaired now).
please any help will do before i garage her and get ripped off big time!!!
It could of melted the bit the relay plugs into
or theirs a dodgy connection on the same part
or maybe it's blown a fuse elsewhere (but i dont know if it's connected to any fuses.)
all i can think of
the old relay that blew can be fixed by DazC off this forum
p.s. i need one
all i can think of
p.s. i need one
I had a very similar problem when i fitted a new fuel pump relay, it turned out to be the connections in the relay socket, they had gone a bit wide so i tightened them up with a small screwdriver and it worked straight away.
Might be worth a try ?
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
rog
Sep 4, 2015 12:10 PM
borboyous
Aug 22, 2015 11:17 AM
