dilemma
Old Nov 17, 2005 | 09:39 PM
jezRS's Avatar
jezRS
Default dilemma
i dont know whether to break my RS or get it fixed
it needs a new gearbox at a price of 1500 quid - but i have little funds at the mo and wil require saving money
question is how much are they worth in bits do people reckon
even if i get it fixed i wil stil need to look in to gettin a diesel as i wil b commuting to work (lookin at a SMART cdi - 90 to the gallon!)
Old Nov 17, 2005 | 11:03 PM
antony215's Avatar
antony215
Escort Rs Turbo
Ł1500 for a S2 gearbox is that solid gold
Old Nov 17, 2005 | 11:26 PM
adamS2RST's Avatar
adamS2RST
That'll be a proper stage 2 plus bernie box then?
Looks like u got a bit of a spec from your sig...what kinda power do you put down? - What box did you run before?
Old Nov 17, 2005 | 11:34 PM
sufsRS's Avatar
sufsRS
give it to me if you want on a serious note if you cant afford to keep spending the cash then break it
Old Nov 18, 2005 | 06:34 AM
JayRS2000's Avatar
JayRS2000
dont ppl use a desil gearbox stronger and probly a lot cheaper i payed 200quid awhile back for my gearbox why is it so much ?
ps car looks nice in sig
Old Nov 18, 2005 | 06:37 AM
adamS2RST's Avatar
adamS2RST
No, that's a common myth. The deisel box is no stronger, has no LSD so all you get is one wheel spinning up so its shite. The box is supposed to have a slightly longer gear ratio but nothing more, so in other words dont bother, you can get a good lsd box for Ł150 odd. But seeing as he seems to run a half decent spec I should imagine a standard box wont last
https://passionford.com/forum/viewtopic.php?t=154946
Old Nov 19, 2005 | 10:54 PM
stuart collins's Avatar
stuart collins
Should b able to get a second hand box for around Ł200 , recons are only Ł550ish
Old Nov 20, 2005 | 09:49 AM
Oranoco's Avatar
Oranoco
As Adam says the diesel box is shite. Wouldn't even consider insulting my RS by fitting one.
With the spec you are running you will need something pretty hefty to stop the car eating the new box. Buy a cheap box and turn the boost down while you save for the proper box. Or just lay the car up over winter so it doesn't get fucked. You'll be surprised how quickly you can save that sort of money when you want to
Old Nov 20, 2005 | 10:24 AM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
or get in touch with jano oddkid and see what he could sort you,he may buy it as it is,worth a try,or even buy a cheap rs turbs,take the bits you need,then sell it off bit by bit, juss an idea!
Old Nov 20, 2005 | 11:19 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Loads of choices other than a 15 year old battered RST box
Whats the point of using a box that someone has already given a hard life.
Old Nov 20, 2005 | 12:37 PM
ze-vh phil's Avatar
ze-vh phil
you can have a box re-built and have a quaife atb diff fitted for less than 1500 notes!!!
Old Nov 20, 2005 | 01:05 PM
jezRS's Avatar
jezRS
it is a cts stage two box - mainly cause i need it to hold the power
i reckon it would be around 260-280 bhp
destroyed the standard box after 200 miles on full boost - too much torque
Old Nov 20, 2005 | 01:56 PM
adamS2RST's Avatar
adamS2RST
Are you saying you broke a cts stage 2 box? or that's what you want? I'd've not botherd with a standard box with that power! or turned the boost right down! And, I didn't think they were quite that much? http://www.gearboxman.co.uk/psgearboxes.html
Old Nov 20, 2005 | 02:20 PM
Oranoco's Avatar
Oranoco
Bernie's Satge 2+ has coped with Sunny's power in his 178mph Zetec turbo monster
Old Nov 20, 2005 | 04:11 PM
Taylor's Avatar
Taylor
Reckon you will get something sorted out,get the boost dow,get saving you will have the cash in no time if you put your mind to it!
Old Nov 20, 2005 | 06:01 PM
Matt_B's Avatar
Matt_B
why not just fit a cheap standard box for now and run less power, at least you can keep what looks like a very smart RS
Old Nov 20, 2005 | 06:35 PM
JimmyBoy's Avatar
JimmyBoy
I would just run less power allowing you to use the car with a standard box. While your using it, save up for a bernie box, at least you would still be getting use out of your S2, and it would seem such a shame to break it - everyones doing that! lol, we gotta keep some of them alive!
Old Nov 20, 2005 | 09:10 PM
Dan's Avatar
Dan
Wow some wicked boxes on there mate, so are you saying you've broke a Stage 2+ box?
Old Nov 23, 2005 | 10:55 PM
jezRS's Avatar
jezRS
no broke the standard box needs a bernie stage 2
put her in storage yesterday - missed her so much
Old Nov 24, 2005 | 10:05 AM
adamS2RST's Avatar
adamS2RST
Get saving the pennys, putting the car away for a while will help you a fair bit!
boeb
Jan 9, 2020 05:11 AM
Daniel Howard
17
Sep 26, 2015 12:39 AM
coswurv
13
Apr 3, 2009 06:47 PM
McPikie
25
Jul 11, 2004 06:59 PM
