Series 1 takes 10mins to start!
Old Nov 17, 2005 | 06:33 PM
stusfesta's Avatar
stusfesta
Default Series 1 takes 10mins to start!
hi, this morning it took 10mins of turning my car over for it to start. any ideas? ive been having problems but since today it has always started after a couple of tries. Ive had the dizzy off and cleaned it up, also cleaned the plugs up. Once the engine is warm it starts fine, its just in the morning and after work. Help !!
Old Nov 17, 2005 | 06:39 PM
AJC's Avatar
AJC
cold start injector is a poss, but i dont think it would take that long if
it were not working, sure some one else will think too
Old Nov 17, 2005 | 07:36 PM
MikeyXR2i's Avatar
MikeyXR2i
Does it splutter and try to fire when Cranking?
Old Nov 17, 2005 | 08:45 PM
stusfesta's Avatar
stusfesta
its not the cold start injector because when it does start it does rev higher which its ment to. I get the odd splutter every now and then, then it splutters and starts then is smooth as ya like
Old Nov 17, 2005 | 09:35 PM
MikeyXR2i's Avatar
MikeyXR2i
I would suggest that you could start looking around the Metering Head for small weaping leaks, especially the electromagnetic Pressure Actuator, small leaks here will let the fuel pressure drop off over night, then there won't be no pressure for it to start. Had this with mine, even though i don't use it, it was when id pull it out the garage it wouldn't start, but soon as it had been running it would, but then come the next day for instance and it wouldn't start.
Old Nov 17, 2005 | 10:06 PM
dave_y's Avatar
dave_y
i have this on my series 2 turbo. it takes a few seconds to start up and tries to fire when cranking.
when its warm its starts immediately every single time.
Old Nov 17, 2005 | 10:10 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
mines the same
Old Nov 17, 2005 | 10:13 PM
MikeyXR2i's Avatar
MikeyXR2i
I can leave mine for weeks now and it will now fire straight up, without no throttle nothing! Get checking the fuel system!!
Old Nov 18, 2005 | 05:15 PM
stusfesta's Avatar
stusfesta
rite, THIS MORNIN really pissed me off was out on my drive tryin to start it at 6.45! no joy! so after fekin about checkin it was sparkin and everythin which it was, i took one of the injector pipes off and turned it over. No petrol was comin through at all. SO i took the plugs out (AGAIN!) and put a bit of petrol in each cylinder, plugs back in fires up first time and kept goin! So now im thinkin it has to be losing pressure over nite like you said but howcome it doesnt stall after ive burt off wot ive poured on the pistons? is it just not building up enough pressure wen turning over?
cheers for ya help so far guys
Old Nov 18, 2005 | 09:31 PM
addiction's Avatar
addiction
you will only get a tiny dribble of fuel out if you take the the injector line off and crank it over!! you have to push the flap down in the metering head at the same time to get it to jet fuel out!!
try disconnecting the cold start valve.
Old Nov 19, 2005 | 08:22 PM
1.9s1's Avatar
1.9s1
i had similar problems with mine when i first bought it, after much messing around it turned out to be a dodgy fuel pump relay. worth a try
Old Nov 20, 2005 | 06:07 PM
stusfesta's Avatar
stusfesta
Rite, found a tiny petrol leak from where the fuel line goes in2 the filter so went to Ford and got couple of new copper washers which solved the leak. It still doesnt like starting but at least it actually starts now! ive disconnected the cold start valve 2. its definatly not the fuel pump as you can hear it workin
Dahl88
Aug 22, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
Sultzi
12
Aug 16, 2015 01:08 PM
saph in dorset
Aug 14, 2015 10:10 AM
ginger1979
Jul 31, 2015 09:56 PM
