Whining Noise when running above 15PSi
Old Nov 16, 2005 | 06:15 PM
davidnormanuk's Avatar
davidnormanuk
Default Whining Noise when running above 15PSi
When running my Cabbie RS I get a loud whining noise coming from the front when running above 15psi. I've checked all boost pipes etc and can't find anything wrong. It has been mentioned that my Turbo could have oil starvation when boosting above 15PSi could this be the cause I am running a standard new Oil Pump which is running good pressure. Do I need to upgrade to a better oil pump when running above a certain PSi.
Dave
Old Nov 16, 2005 | 06:42 PM
JimmyBoy's Avatar
JimmyBoy
Im not sure, but dont turbo's "whistle" when they are out of balance ?, the turbo you have may not be balanced 100%, and may be fine at say 10psi, but that extra few psi you are running may be pushing it a bit too hard and therefore you get a whistling kind of noise.
I may be wrong, just an idea.
Old Nov 16, 2005 | 06:52 PM
davidnormanuk
Your not the first person to have said that. I might have to take it back to where it was rebuilt and get them to check it.
Old Nov 17, 2005 | 07:54 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
If your oil pressure is good then don't worry. It will have no effect on what boost you run. I use a standard oil pump with a huge oil cooler and near 29psi boost, no probs.
Is it a standard turbo? I had a stage 2, and a stage 3 T3 that screamed really loudly at high boost, was just the air going through the compressor housing.
Old Nov 17, 2005 | 12:34 PM
DanS's Avatar
DanS
Mine did that too............ then it went bang
Old Nov 17, 2005 | 03:56 PM
Tony Turbo's Avatar
Tony Turbo
Oooops... I sold mine
Old Nov 17, 2005 | 05:32 PM
davidnormanuk
Hmmm. I might get mine checked out then. Its still under warranty so I'll phone them and see what they say. Thanks for the help much appreciated.
Old Nov 18, 2005 | 03:39 PM
zippyobrien's Avatar
zippyobrien
ive got two rs turbos.
ones got a standard turbo, panel filter and 12psi,
the other has got a stage 3 turbo and 24psi.
the standard one still whistles (excuse my spelling, its shite) although it whistled more with a cone fillter on it.
the stage three sounds much much louder.
i thought it was just the air going through the compresor housing that makes the noise,
Old Nov 22, 2005 | 10:22 AM
davidnormanuk
The turbo is a hybrid with a .48 housing and 360 bearing.
It pulls like a train just make the noise. Might get it checked out anyway just to be safe.
Dave
Old Nov 26, 2005 | 08:34 PM
RST Ski's Avatar
RST Ski
mine screams/whistles on hard acceleration too, wierd! not runing much boost tho, only 132bhp
dombanks
Sep 21, 2015 08:38 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
rsturbo27
Sep 5, 2015 05:08 PM
fuzzy
Sep 4, 2015 10:11 PM
