Pictures of the damage to the garage roof :cry:
Team HOTHOT!
lucky the garage door held up really
this is how it was when starting - all very nice and good
and as seen here, supports the weight of the engine on its own no problem at all
then when refitting everything and lifting and supporting the engine and gearbox, the support beam collapses bringing with it long time lovely plasterboard and black lime, a striplamp tube into my engine bay
Quick fix with cable ties late last night (circa midnightish) so i could close the garage door
How many tims of WD40? - must of been a catering pack
luckily the only damage to the car is a couple if minor scratches on the wings which may polish out, may not
Team HOTHOT!
that picture with the engine out was taken after i spun it round and put the brace on as a resting beam to take the weight while i pulled the flywheel off etc
i've had engines swinging from the rafters before now with no problems - looks like i'm gonna have to get that metalfram welded up and put in asap
PassionFords Creator
Originally Posted by Graceland
Stu - engine was out for rear crank seal - cheers for that little bit of advice on the phone yesterday too
YOU TOOK IT OUT TO DO THAT??!!??!
Team HOTHOT!
yep, took it out to do that as there was a few other little jobs that needed addressing aswell and it was easier to whip the engine out rather than struggle on my own attempting to remove the gearbox
Team HOTHOT!
i would of done that Stu, but i have a philosiphy of if it aint broke don't fix it, unless you do it properly - and i'll be paying you to do the properly bit next year all been well
now i've said that, it's gonna go pop at the ring
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
