Just a quickie about big end bearings
Vauxhall bearings, says 'upper' on four of the bearings and 'lower' on the other 4
Just wondered if the 'upper' ones go on the rod, and the lower on the cap?
Ta
Ta
Wicked, cheers
I thought i would double check just incase, pistons and rods are going in today
Can't wait.
Pics later
Have a look at the counter sunk caps, i had them done properly, none of this 'self centering with a power drill' bollocks
They so lully, and perfect too! had the ARP bolts measured aswell, again, perfect, and handy to know so i can measure them at the next rebuild to see how much they tretched
http://img333.imageshack.us/img333/3850/cimg22053it.jpg
Can't wait.Pics later
Shite, Chip, u made me think about something.
My big end bearings had no holes in them! yet the rod had a hole right through it! Shouldn't my big end shells have holes in the upper one?! How the fuck do they stay lubricated!?!?
PassionFords Creator
This is a very graphic case of "A little knowlege is dangerous"
If chip hadnt happened to mention that, you would have lost that engine once you got it nice and hot
Indeed Stu, but at least Spence knows when he needs to check things normally
Spence, you have a few choices here mate:
Get some bearings with the holes in
Drill your bearings
Install squirters
Basically the bearings you have are what people like SBD sell as an upgrade on the N/A engine, where the squirter isnt needed due to the lack of heat in the piston.
Drilling them is acceptable, but awkward and obviously you MUST chamfer it off after to make sure there is no sharp edge, i would not recomend this option.
Installing the squirters is a fantastic idea, they have pressure switches in them (spring loaded ball) so they will never starve the crank of oil and yet will still keep the pistons nice and cool, in fact they flow MORE oil in good pressure situations than the standard holes do.
I would go for that option personally.
I know someone who will install them for you for a ton including the supply of the nozzles, but it has to be done into a bare block and its your responsibility to ensure the swarf is properly cleaned out afterwards (it will come back cleaned anyway, but only quickly)
Drill your bearings
Install squirters
Fuck it
The pistons and crank and everything is already in
Did the LET have holes in the big end shells? I got the 1.7 D/TD bearings see.
I'm not looking to run more than 250bhp now, will i still need to sort it out? The crank is all torqued down now, and i will need new bolts, reseal the end caps, its long
Why will you need new bolts?
Yes the LET had them as standard!
What tool told you to put the 1.7TD bearings in it?
I also recall mentioning that it will be turbocharged, so anyone who knew what they were on about would have picked up on the under piston cooling problem using the shells i got now.
Ah well, shall i drag the pistons out again and fit the new shells? Or shall i fit them whilst still inside the engine? There seems to be plenty of space to mess about with
P.s the crank bolts i got are single use apparently
I dont see how a crank bolt can be single use.
Crank and rod bolts are always torqued to before their point of elasicity.
did you accurately measure the length? If so you can check them.
Failing that, an ARP stud and nut kit like mine is a good investment at under 100 quid.
you can easily change the bearings with the pistons in place.
you cant install the squirters though due to risk of swarf getting somewhere it shouldnt, block must be stripped first, and thoroughly cleaned after.
Cheers Chip
I just been down SBD as i only live 10 minutes away, and i asked them about the bearings i got being run on a LET and they said it will be fine and that all their engines they build use those bearings
But i don't want to tempt fate, so i may just go down vauxhall and get some as SBD don't stock the ones with the hole
I'm at a point now where i have 3 differn't opinions, and to be honest, i trust your judgement over SBD and that tool on mig from ages ago.
Most of SBD's engines are using steel rods which have "buckets" on the should of the rods to throw oil up at the piston.
Maybe thats why they dont feel the need for the standard squirters?
Put it this way, go and try and find me ANY standard turbo engine without some form of spray, cause the only one i can name is the metro turbo with a heady power figure of 93bhp
lol yeah good point, i didn't mention that they are standard rods. I'll E-mail them again to tell them and see what they say just out of curiosity
Anyway, off to vauxhall i go
They DO know what they are on about down there, they've built some serious motors, although mainly N/A they have done turbo stuff for motorsport too i know (not on standard rods though)
I'll see what they say, like you said, would be interesting to know.
EDIT: Think they answered the question in the first E-mail to tell the truth, even mentioning their rods
Dear Spencer
Thank you for your email. The bearings we supplied are the correct ones for
your engine. None of our bearings have oil holes in them. We have found you
do not need to use bearings with holes as they are not needed. Even our
steel rods for the ultimate spec engines do not have oil holes in them. If
you really want an oil hole, then you can drill back from the rod through to
the bearing and make your own oil holes. But to be honest with you, they are
not needed. There is plenty of oil spray from the side of the bearing when
it gets squeezed out.
If you want to ring and have a chat about this, please do.
Regards
Dick
Regards
Dick
Well, here's the reply....which sounds like they arn't 100% sure now
No, we have never built a turbo engine ourselves using these bearings. We
have sold lots of these to many different customers, trade and retail and
have not had anybody come back to us with a problem. As with all motorsport
components, there is no guarantee. If you want to use a heavy duty bearing
then these are the only ones available. As we said when you called in, we do
not supply anything else and you can always have the oil hole drilled if you
are unsure.
Regards
Dick
are unsure.
Regards
Dick
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
