What is needed to fit Cosworth brakes to an RS Turbo??
Old Nov 15, 2005 | 06:41 PM
TIFF's Avatar
TIFF
Chasing Radders
Default What is needed to fit Cosworth brakes to an RS Turbo??
As title
And what is it like as a conversion?
Old Nov 15, 2005 | 06:43 PM
Ginge !'s Avatar
Ginge !
just finding my feet
what ones, 4pots or 4wd ones and 2wd discs
Westy's Avatar
Westy
tell you what Tiff...
cossie brakes is definatel;y a good start..
what you going for... 4 pots off of 2wd, or just a set of 2wd discs retaining the rst calipers??
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
2wd discs and 4x4 calipers should bolt straight on! may need a washer thats all you will see when bolting them up
Old Nov 15, 2005 | 06:45 PM
Westy's Avatar
Westy
4x4 calipers.. are they really an upgrade???
why not fit a set of 4 pot calipers, as these would definately be an upgrade.
Old Nov 15, 2005 | 06:46 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
they need to be machined...
4x4 ones dont iirc
Old Nov 15, 2005 | 06:47 PM
Westy's Avatar
Westy
fair comment...
but what im saying is, what makes the 4x4 caliper better than the RST one?? Its a serious question as i dont know the answer...
Old Nov 15, 2005 | 06:48 PM
TIFF's Avatar
TIFF
Chasing Radders
So it is just a straight swap over then?
I assume there is a noticable difference
Charlie Chalk
Unknown.
think the pads have a bigger space, so more grip onto the disc...
Not sure tbh
Old Nov 15, 2005 | 06:50 PM
Westy's Avatar
Westy
ok cheers..
p.s. get your own thread westy
sorry tiff
Mr S1's Avatar
Mr S1
Don't ask - I don't know
As RS Gus - mine went straight on, but had to remove the inside stick on weights, it's that close. Maybe easier to get the discs machined as mentioned.
Old Nov 15, 2005 | 06:51 PM
Charlie Chalk
Unknown.
I take it were still talking under the Standard S2 alloys..
Old Nov 15, 2005 | 06:53 PM
Shings's Avatar
Shings
Mark
I put Cossie 2wd 4 pots on the front of my car.
I wasn;t that impressed to be honest- a good set of pads and discs were just as good if not better.
They had to be machined and a washer used to space them correctly.
Jake
Old Nov 15, 2005 | 06:54 PM
Shings's Avatar
Shings
Oh yeh-
COSSIE 2wd brakes wont go under S2 alloys- need spacing quite considerably
Old Nov 15, 2005 | 06:56 PM
Rs Gus's Avatar
Rs Gus
4x4 brakes are a very good upgrade had em on my s2
Old Nov 15, 2005 | 06:59 PM
TIFF's Avatar
TIFF
Chasing Radders
So the conversion wont fit under RS Turbo wheels??
Old Nov 15, 2005 | 07:01 PM
Ginge !'s Avatar
Ginge !
shings they do go under
Rs Gus's Avatar
Rs Gus
tiff straight under s1/s2 wheels with 4x4 calipers as i said straight on
Old Nov 15, 2005 | 07:05 PM
Shings's Avatar
Shings
2wd calipers DO NOT 100% not at all ever ever no chance in a million years.
There is no way they will go under S2 wheels- I even tried grinding metal out the back of the wheels to fit em on. ( Chad still has the wheel to proove it LOL)
Old Nov 15, 2005 | 07:09 PM
Ginge !'s Avatar
Ginge !
strange ive seen it before
but who has stadard wheels anyway
brom managed to fit 315mil discs and focus RS calipers under my mondeo wheels with little( ) fuss and mods
Old Nov 15, 2005 | 07:10 PM
Mr S1's Avatar
Mr S1
2wd calipers won't fit under S2 rims - Shings is spot bollock on.
Need 4wd calipers.
Old Nov 15, 2005 | 07:12 PM
TIFF's Avatar
TIFF
Chasing Radders
Jake
Did Lucks tell you they didnt fit?
Old Nov 15, 2005 | 07:13 PM
Ginge !'s Avatar
Ginge !
im gonna make sure that i try a standard set of wheels on me car when i finish me brake conversion on the cabrio just to test and prove it can be done
Old Nov 15, 2005 | 07:17 PM
Rs Gus's Avatar
Rs Gus
i never said 2wd calipers fit! you dont want 2wd calipers anyhow they are toss 4x4 is a rilliant conversion for the money
Old Nov 15, 2005 | 07:25 PM
Shings's Avatar
Shings
Jake
No mate- I found out for myself....
Remember when I crashed my car.
The reason why?
I had to put those SHITTY 3 door rims on because the S2 wheels wouldn't go over the brakes that I put on at the same time as the conversion.
Hence shit tyres
Shade
Trees
LOL
Jake
Old Nov 15, 2005 | 07:27 PM
Shings's Avatar
Shings
Incidently- its the size of the caliper not the size of the disc- the shape of the rear of an S2 wheel means they wont go on the hub.
Old Nov 15, 2005 | 07:42 PM
Hardeep_Singh's Avatar
Hardeep_Singh
Tiff i have this setup on mine 2wd disc's and 4x4 calipers all that is needed is two small washers (10 mm thick) nothing else!
they work excellent on mine but i have also removed the crappy ABS units, ask karl what he thought of the brakes if he can still remember!
Old Nov 15, 2005 | 08:11 PM
TIFF's Avatar
TIFF
Chasing Radders
Cheers All
Old Nov 16, 2005 | 08:34 AM
PGT's Avatar
PGT
if you put 16" wheels on you can fit rsfocus 324mm discs using s2 calipers. massive increase in braking power. needs some caliper machinening and a spacer between the flange and wheel.
as someone said above 'whats the benefit in 4x4 calipers?' , they have 60mm single pistons just like s2.
Old Nov 16, 2005 | 10:16 AM
Wazzzer's Avatar
Wazzzer
I've got 2WD Cos setup front and rear on mine and it made a lot of difference, might have been cos I binned the ABS at the same time though.
I had to use a 5mm spacer on my 17s on the front to get the wheels over the calipers, but strangely I borrowed my brothers Zetec-S rims and they went straight on with no hassle...
If you do the 2WD setup give Ryan a shout as he got mine machined for me, they fitted straight on with no washers
JoeyBoyden
Jan 4, 2024 02:36 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
col93saphcos
Aug 7, 2015 03:21 PM
