Bro's S2 back fires when turned off
Old Nov 15, 2005 | 05:12 PM
richard_xr2i1800's Avatar
richard_xr2i1800
Default Bro's S2 back fires when turned off
Hello everyone quick question, my bro's s2 turbo back fires when you turn it off what could it be, we know its not the timing as thats just been done, its also a pain to start
Any ideas
Rich
Old Nov 15, 2005 | 05:46 PM
andyt's Avatar
andyt
Mine does it mate he needs to let cool down a bit longer before turnig the car off, was on here that it would`nt do any harm or damage
Old Nov 15, 2005 | 05:56 PM
RS_JAY's Avatar
RS_JAY
Even still...Thats not right.
Old Nov 15, 2005 | 06:23 PM
richard_xr2i1800
its odd, its brand new engine and turbo build just ran in
Rich
Old Nov 15, 2005 | 06:47 PM
andyt's Avatar
andyt
my engine is nearly run in and it does it, i asked about this a few month back and was told it was ok, a few of the lads cars do it off here
Old Nov 15, 2005 | 08:01 PM
Rick's Avatar
Rick
loadddddddds do it. Let it cool a bit longer.
Old Nov 15, 2005 | 08:53 PM
stevenebm's Avatar
stevenebm
post whore
mines done this.doesnt matter how long you leave it.think its overfueling and when u switch off its a wee bit o fuel backfiring.know what a mean.is the exhaust pretty sooty.
Old Nov 15, 2005 | 08:57 PM
turbo.jon's Avatar
turbo.jon
mine do it but thought it were timing as it need setting up but my exhaust is pretty black so look like its over fueling a little i can leave it 5 mins and turn off and it still do it ..... funny whan people walk past back of your car or when u pull up at petrol station
Old Nov 16, 2005 | 11:24 AM
Rick's Avatar
Rick
Most KE injectors weep a little. If the CO is turned up a lot, the metering flap is slightly depressed, and it will dribble fuel in once it's turned off, and this will ignite a few seconds after switch off. You also get restarting problems as it's flooded.
Old Nov 16, 2005 | 04:05 PM
ballin's Avatar
ballin
leaky injectors normally
Old Nov 16, 2005 | 04:09 PM
richard_xr2i1800
nice cheers peole, would lecky injectors cause the bad starting? also are they easy to buy new
Rich
Old Nov 16, 2005 | 05:34 PM
my S2 does it sometimes, mainly when i pull into a petrol station and dont let it cool down for a bit. i noticed it only does it when its very cold...but thats probably just a coincidence
Old Nov 16, 2005 | 05:38 PM
rstdave's Avatar
rstdave
Mine did it before and after i had me new engine put in!! Don't do any harm from what i've bin told, is only after i've bin canin it and not lettin cool down enough tho!
Old Nov 18, 2005 | 03:42 PM
PaulT's Avatar
PaulT
Mine does it since i heat wrapped the manifold and turbo.
PaulT
Old Nov 18, 2005 | 03:47 PM
zippyobrien's Avatar
zippyobrien
heat wrapping the turbo and manifold would hold more heat in the exaust and cause any left over fuel to ignite easyer.
mine has done it before after a gentle 5min run, did have shit plugs and a miss fire tho?
Old Nov 18, 2005 | 05:01 PM
richard_xr2i1800
cool cheers all, his manifold is heat wrapped
Rich
Old Nov 20, 2005 | 04:53 PM
James Raby's Avatar
James Raby
Not to worry, mine does it too
As Rick say, very common
Just let it cool down after a caining, by this I mean drive sensibly before you pull up at your house!!
Old Nov 20, 2005 | 11:18 PM
AKRS1's Avatar
AKRS1
sounds like thats whats happening and both my rs turbos have done it but i think all rs turbos do this
The Underdog
29
Sep 7, 2015 09:49 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
sridgett
18
Aug 1, 2015 08:49 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
