cosworth parts (with pics)
i have a few cossie bits up for grabs starting with this
200 block bottom end in need of new pistons and a re-bore it's got an escos crank and was running low comp the bore size is approx 92mm £SOLD
set of ecu's l6 with stg 1 chip,abs, lamp failure & electrical test £130 the lot
2wd inlet manifold with yellow injectors,fuel rail, pressure reg &throttle cable bracket £40
2wd rear callipers been stood a while £25
-31 actuator £30
cloth interior front, rear seats, doorcards, centre console & parcel shelf in vgc with 2 slight tears on drivers seat £120
standard airbox £15
late spec dashboard black except the piece under steering wheel £45
set of lights headlights,with wipers, clear indicators, smoked rear & number plate surround £50
side skirts in mercury grey only 1 jacking cover £SOLD
electric mirrors in moonstone blue bit of paint flaking off on the bottom £20
-31 actuator £30
standard airbox £15
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
