fuel metering head?
Old Nov 12, 2005 | 06:44 PM
sfaki2005's Avatar
sfaki2005
Default fuel metering head?
there is a grey plug that clicks on the side of the metering head, when this is connected and i try and boost my car it holds back immediately, if i disconnect it and leave it hanging off then car boosts ok.
any ideas what this plug is or does and why this will happen when connected??
please advise.
thanks
Old Nov 12, 2005 | 07:23 PM
Rick's Avatar
Rick
This plug supplies current to the Electromagnetic fuel pressure actuator. The fuel ecu collects info from all the sensors, and adjusts current to fine tune the fuelling.
Sounds like one of your sensors is fauly/not connected. You shouldn't really run with it disconnected.
Old Nov 12, 2005 | 07:36 PM
DazC's Avatar
DazC
Unless you fancy a big engine rebuild bill!!
Old Nov 12, 2005 | 07:47 PM
sfaki2005's Avatar
sfaki2005
thanks for the replys, which sensor do i check?
can it also be the fuel ecu?
Old Nov 12, 2005 | 07:51 PM
Rick's Avatar
Rick
all of them!
and yes, it could be.
Old Nov 12, 2005 | 08:16 PM
DazC's Avatar
DazC
Start with the coolant temp sensor and then check the rest.
Old Nov 13, 2005 | 10:50 AM
kossie's Avatar
kossie
Ah so its the coolant temp sensor that goes to the fuel ecu? Been trying to find that out this week
JK12
33
Apr 26, 2021 12:09 PM
jessie_rs
62
Aug 6, 2019 09:27 PM
dombanks
Sep 21, 2015 08:38 PM
kevin36
Sep 8, 2015 12:23 PM
hopper350
Sep 4, 2015 12:53 AM
