Actuator preload....
Old Nov 12, 2005 | 06:13 PM
Dave McB's Avatar
Dave McB
Default Actuator preload....
Hey all.
the actuator on my car needs re-set due to it popping off the wastegate of the turbo.
Rather than the old try/fail/adjust technique, id there any way i can set the preload on a -31(4x4 saf turbo/manifold etc) to around 16psi (on the safe side)
Old Nov 12, 2005 | 06:20 PM
SPADGE's Avatar
SPADGE
Set it at half a hole of pre-load and adjust the jetting in the amal valve until its running the correct boost pressure!
Old Nov 12, 2005 | 06:24 PM
boXXer's Avatar
boXXer
GASH!
if it only popped off, would it need re-setting as they have lock nuts if i remember? if not, spadge has the answer!
Old Nov 12, 2005 | 08:14 PM
Dave McB's Avatar
Dave McB
sorted it, but how do u adjust the jetting in the amal valve???
Old Nov 13, 2005 | 11:17 AM
rabmc's Avatar
rabmc
yess as above
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
