Why oh why is my camshaft oil seal leaking?!?!?
Old Nov 12, 2005 | 03:06 PM
GraphiteGray's Avatar
GraphiteGray
Default Why oh why is my camshaft oil seal leaking?!?!?
As title the camshaft oil seal leaks when the engine (CVH) warms up up to normal temperature, coating the cam sprocket and spraying it everywhere
Ive fitted two new seals, one from a motor factors and one from Ford but its still doing the same, WHY!?!?
Am i fitting it wrong? would running on thinner oil do this? any ideas? talk about throwing a spanner in the works
Anyone?
Gray
Old Nov 12, 2005 | 03:41 PM
320 bhp's Avatar
320 bhp
CAM NOT WORN WHERE SEAL FITS OULDNT TAKE MUCH 2 MAKE IT LEAK
Old Nov 12, 2005 | 05:38 PM
GraphiteGray
Its a brand new Kent cam, just run in
Old Nov 12, 2005 | 05:42 PM
320 bhp's Avatar
320 bhp
DONT TAKE THIS THE WRONG BUT R U FITTING IT THE WRITE WAY ROUND IT THE ONLY OTHER THING I THINK IT COULD BE IF IT A NEW CAM AND OIL SEAL
Old Nov 12, 2005 | 06:14 PM
GraphiteGray
Fitting it the right way round not sure how far i should push it into the head though perhaps im not fitting it properly
Old Nov 12, 2005 | 06:18 PM
320 bhp's Avatar
320 bhp
I ALWAYS FIT THEM FLUSH WITH THE HEAD
Old Nov 12, 2005 | 07:10 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
take the rocker cover of and you'll see.
could the head be worn? causing the cam to sit slightly off, leaving a gap for ouil to leak?
Old Nov 12, 2005 | 07:46 PM
GraphiteGray
could the head be worn? causing the cam to sit slightly off, leaving a gap for oil to leak?
I hope not the head was recently rebuilt by Burtons could it be because ive not pushed it in square? think ive been putting them in wrong
Old Nov 12, 2005 | 08:00 PM
320 bhp's Avatar
320 bhp
JUST MAKE SURE IT SITS FLUSH WITH THE HEAD AND ITS THE WRITE WAY ROUND NICE AND CLEAN AND U SHOULDNT HAVE A PROBLEM
Old Nov 12, 2005 | 08:09 PM
GraphiteGray
Another thing i thought of, ive used 5w-30 castrol GTX magnetec, you know that stuff you have for the modern Zetec i bought it buy mistake and only noticed when i was filling the engine
Ive done 0 miles with the oil in as ive barely started setting up the engine, im sorting out too many problems like this am planning to change it for the proper stuff soon as it'll probrably have swarf in it where i refitted the head etc
It only leaks when up to normal running temp, from cold its fine
Old Nov 12, 2005 | 08:35 PM
vroooom ptssssh
It Wasnt Me!
Maybe the oil is slightly too thin
Old Nov 12, 2005 | 09:14 PM
GraphiteGray
well we'll see tomorrow cos im gonna change it for some decent stuff
knowing my luck it'll still be leaking
Old Nov 12, 2005 | 09:23 PM
Rick's Avatar
Rick
nothin to do with the oil
u have to press it in quite firmly. should be flush, or just protrude slightly from the head.
Old Nov 12, 2005 | 10:17 PM
vroooom ptssssh
It Wasnt Me!
good luck
Old Nov 12, 2005 | 11:10 PM
GraphiteGray
good luck
Cheers ill need it
keep you posted
timsrs
Nov 13, 2018 11:48 AM
Cosnada
Jan 7, 2016 05:30 PM
muzzman1
Sep 30, 2015 08:59 PM
