Stripping a S2 gear box
Old Nov 12, 2005 | 02:47 PM
Patto's Avatar
Patto
Default Stripping a S2 gear box
i have a growling noise coming from wot we think is the box! not sure whether its diff or box! either way it's gotta come to bit's taking the box to bit's isnt a problem but unsure on the diff ( think they have to be set up? ) any idea how much or if you can get an exchange on a recon box!
CheeRS
Craig
NYRSOC
Old Nov 12, 2005 | 02:59 PM
GVK's Avatar
GVK
What tends to happen on those B5 boxes is the mainshaft end bearing goes and chews up the main shaft and the casing with it.
Standard bearing doesn't have an inner race and the rollers run on the mainshaft
You can get them modified to take a stronger bearing these days
When I had my S2 RST the 'box failed about 6 times within 2 years, always the same thing
Old Nov 12, 2005 | 03:28 PM
same here
buy onr from gearboxman
Old Nov 12, 2005 | 03:34 PM
Patto's Avatar
Patto
one step ahead of you mate looks like he'll be sending one my way!
CheerS
Craig
NYRSOC
TPM961
Jan 15, 2018 10:50 AM
`spotty
Sep 25, 2015 11:41 PM
cossirob
Sep 16, 2015 07:39 PM
Flateric_2002
Sep 15, 2015 08:41 AM
