XR4x4---- are the 2.8 and 2.9 flywheels interchangable?
Old Nov 11, 2005 | 07:20 PM
Mark V8's Avatar
Mark V8
Default XR4x4---- are the 2.8 and 2.9 flywheels interchangable?
I've just bought a 2.9 XR4x4 and a 3.9 V8 engine on Ebay and plan to do a 4 wheel drive V8 conversion using the MT75 gearbox, an adaptor plate and one off flywheel to use the Ford starter motor. I have access to a 2.8 flywheel to measure up but need to know if it is compatible with the MT75 box and starter motor? I know 100% that a cossie 4x4 cluch fits the 2.9 flywheel, will it fit the 2.8?
If not does anyone have a 2.9 flywheel nice and cheap?
Thanks for any help, I will post pics when conversion is under way
Mark
Old Nov 11, 2005 | 07:30 PM
Graceland's Avatar
Graceland
Team HOTHOT!
the flywheels are interchangeable on 2.8 and 2.9 yes - as its the same block.
however, the clutches arn't the same due to different gearboxes - type9 on the 2.8 and mt75 on the 2.9
Old Nov 11, 2005 | 07:34 PM
Graceland's Avatar
Graceland
Team HOTHOT!
edit to say, the clutch covers arn't the same, the spinner plates are tho
Old Nov 11, 2005 | 07:59 PM
GOT2BZETEC's Avatar
GOT2BZETEC
Going to do somethink similar with a 3.5 turbo onto a 2wd gearbox, altho have been told leyland van gearbox is best as strong and reallly short will get some pics. Anyway i know you need a adapter plate for the 2wd boxes!
Old Nov 11, 2005 | 08:20 PM
Graceland's Avatar
Graceland
Team HOTHOT!
you van get bell housing off the shelf to mate a T5 to an RV8
Old Nov 11, 2005 | 09:15 PM
Mark V8's Avatar
Mark V8
Looks like I had better find a 2.9 flywheel then, thanks for the info
I allready have a rear wheel drive V8 Sierra using a T5 and adaptor bell housing and it for sale on Ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=4587653264
A V8 4x4 has got to be the ultimate all round Sierra
Mark
Old Nov 11, 2005 | 10:16 PM
Jimboxr4x4's Avatar
Jimboxr4x4
There was one in the Spring edition of Fast Ford. I think it was a 3.5l V8 but not powerful as I remember - about 220 ish bhp.
Old Nov 11, 2005 | 11:10 PM
Doh's Avatar
Doh
the clutch covers aren't the same but they are interchangeable as its to do with the peddle travel i believe, u want the 2.8 flywheel as its lighter
Old Nov 12, 2005 | 05:47 AM
Mark V8's Avatar
Mark V8
So I could use the 2.9 clutch and starter with a 2.8 flywheel and MT75 gearbox without problem? I not actually going to use any of the Ford flywheels but need one as a patern to make a new one with the Rover V8 center and some offset to allow for an adaptor plate, it would be a massive pain in the ass if I spent countless hours making a new one based on the 2.8 only to find that the Cossie clutch wont fit or that the ring gear is a different dia.
Anyone running a 2.8 flywheel on a 2.9 XR4x4 on here?
cheers
Mark
yatta
May 21, 2016 10:31 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
