Hub Nuts someone help im being thick
Old Jul 8, 2004 | 06:37 PM
Ka_rst's Avatar
Ka_rst
Default Hub Nuts someone help im being thick
Ive snapped a drive shaft on the ka so wanna get the snapped piece out to put in a nice new stronger one, but cant seem to get the hub nut off its got a 32mm head which i have a socket for but even with a 3ft breaker bar it wont budge, the haynes says something about having to punch something out anyone the wiser??
Old Jul 8, 2004 | 06:56 PM
Ka_rst's Avatar
Ka_rst
anyone?
Old Jul 8, 2004 | 07:00 PM
richm's Avatar
richm
hub nuts often have a a thin section sleeve extending from the main nut section, which is punched into a groove in the shaft, to act as a locking mechanism. This should be lifted or punched back out of the groove before you undo the nut...
maybe this is what they are referring to?
Occasionally the nut on one side is left-hand thread, which needs to be turned clockwise to undo - don't know if this applies to yours?
Old Jul 8, 2004 | 07:03 PM
NUTS RuS's Avatar
NUTS RuS
Glad I just pressed refresh before typing all the same info as Rich
Beat me to it again
Old Jul 8, 2004 | 07:05 PM
Ka_rst's Avatar
Ka_rst
yeah there is a section that sticks out further than than the nut, it round but on one side has small cut out in it, do i need to nkock something down there to lift it off then?
if you look at the pic below you can see the hub nut and where its green is the cut out
thanks for help
Old Jul 8, 2004 | 07:09 PM
NUTS RuS's Avatar
NUTS RuS
If you can drive a screwdriver down the groove it may help. The nut is peened over into this hole.
Also the next step would be to get something to extend your 3 ft breaker bar with. I sometimes use my big trolley jack handle or a piece of scaffolding pole.
As Rich says though sometimes they are left hand threaded on one side. You can usually tell by looking at it.
Old Jul 8, 2004 | 07:11 PM
NUTS RuS's Avatar
NUTS RuS
U trying to do it with the wheel off ????
Old Jul 8, 2004 | 07:14 PM
Ka_rst's Avatar
Ka_rst
nope ive put the wheel on and taken it off the jack, ill try driving a screwdriver down now and see what happens
Old Jul 8, 2004 | 07:15 PM
richm's Avatar
richm
yes, get the green bit clear of the slot - and you WILL need more than a 3ft bar, like Tony says get a length of pipe on it. You'll need to be doing it with the wheel on and on the ground, or someone pressing the brake.
Old Jul 8, 2004 | 07:30 PM
Ka_rst's Avatar
Ka_rst
ok cheers guys im off to find a scaffold pole now
Old Jul 9, 2004 | 12:13 PM
Damo V's Avatar
Damo V
As above, but just to re-iterate, I reckon you are trying to do it up mate, ie LH thread....
Old Jul 9, 2004 | 12:48 PM
SyKaTurbo's Avatar
SyKaTurbo
If you have snapped the shaft then why are you removing the cv aswell?
Just pop the shaft out on its own. See pics on kaklub.
Once the hub nut is off you will need a probably need hub pull to push the cv out out.
Sierrasideways
Oct 8, 2015 06:37 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
