adjusting boost...
Old Nov 6, 2005 | 12:24 PM
bassboy's Avatar
bassboy
Default adjusting boost...
hi peeps just wondering if adjusting boost via shortening the actuator rod is a harsh way of adjusting it? Boost will only be going up about 2psi
i have heard that by using this method the preload on the actuator will be too much?
oh its a standard turbo and a standard actuator...
is rejetting the amal valve a better way? if so how big do u jet it to? only looking for 10psi...runs about 7.5psi at the moment
cheers
bassboy
Old Nov 6, 2005 | 01:55 PM
bassboy's Avatar
bassboy
anyone?
Old Nov 6, 2005 | 01:59 PM
Oranoco's Avatar
Oranoco
With regards to upping the boost just leave it alone and have it done by a tuner that knows what they are doing. You need the fuel to match the boost and if you get it wrong it ends in expensive tears
Old Nov 6, 2005 | 02:04 PM
bassboy's Avatar
bassboy
Oranoco fuel is all good and there is plenty of fuel there however its just a general enquiry really as some people say that it is from the actuator that you are meant to adjust boost from while others say amal valve?
bassboy
Old Nov 6, 2005 | 03:44 PM
AKRS1's Avatar
AKRS1
why dont you just use a bleed valve
Old Nov 6, 2005 | 03:56 PM
ze-vh phil's Avatar
ze-vh phil
YOU STILL NEED TO ADJUST THE FUEL EVEN IF YOU USE A BLEED VALVE.
Old Nov 6, 2005 | 04:59 PM
bassboy's Avatar
bassboy
ok guys...as said was just enquiring to be honest with u...might give it a try on my engine just to see what happens lol...with disasterous effects knowing my luck on second thoughts...ill wait for more power with my Zetec turbo LOL
bassboy
Old Nov 7, 2005 | 06:29 PM
Rick's Avatar
Rick
basically, you should keep the preload in a certain region. The minimum should be half a hole, the max depends on lots of factors. You know it's too much, as there will be boost creep in the higher gears/rpm levels, where the wastegate just isnt open enough.
Rick.
Old Nov 7, 2005 | 07:15 PM
adamS2RST's Avatar
adamS2RST
I'd usually just adjust by the actuator....but for the sake of upping the boost limit on your unchipped car for the extra couple psi mate I really wouldn't worry for now!
Like you say wait for your proper engine
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
