Holding back when coming on boost
The turbo spins up fine but when it's time to boost it splutters and hesitates and you can feel it holding back.
Also when driving at very low revs, any accelaration makes it do the same kind of thing, it seems to chug and misfire and more revs are needed or a higher gear where it seems ok.
Any ideas??
Any ideas??
Originally Posted by Alex zvh cabrio
when u last change the plugs or fuel fillter?
Originally Posted by antony215
check the timing on the dizzy i just had the same problem done the timing on the dizzy and now it runs fine
CabrioTurbo
Aug 1, 2015 11:04 AM
