What should be replaced? CVH engine!
Well the engine will be out in the next few days (S2 CVH)
What shall I replace to make sure it lives longer? I dont think I am gonna go as far as a full rebuild but all gaskets etc will be changed while it is out but what else shall I do while the engine is out?
What is worth replacing that may give me trouble in the future?
Thanks
Nick
Thanks
Nick
problem is doing rings
is the crank could need grinding aswell
so thats new bearings and a grind
then you mite aswell put oil pump on
then if you want new pistons
its all up to you mate
im here to help as you now, ill try and get 5 mins this week and help you get the engine out but should only take and hr
