How to identify a 4wd head!?
Old Nov 2, 2005 | 12:41 PM
B19-TRB's Avatar
B19-TRB
Default How to identify a 4wd head!?
Dan is gunna go look @ a head for his cossie!
Its a bare head he is lookin @ & will b puttin in 2wd bits from his old head!
Does it matter if the casing is 4wd!? & how can u tell between 2wd & 4wd!? if any differnece in the casting!
Thanx
Old Nov 2, 2005 | 12:44 PM
Graceland's Avatar
Graceland
Team HOTHOT!
4wd head has no leg on the exhaust side for the turbo damper, and also 4wd has grooves in the front cam bearing holes where the locating ring sits in
Old Nov 2, 2005 | 12:45 PM
Graceland's Avatar
Graceland
Team HOTHOT!
and if its a bare head, make sure tha camcaps come with it or it's nearly useless
Old Nov 2, 2005 | 01:03 PM
CraigN's Avatar
CraigN
and it has 3 bolts for the thermostat housing 2wd has 2
Old Nov 2, 2005 | 01:05 PM
Stu @ M Developments's Avatar
PassionFords Creator
Not true, late 2wd had 3 too.
Best and simplest indication is teh turbo damper hanger.
Old Nov 2, 2005 | 01:07 PM
B19-TRB's Avatar
B19-TRB
cheers peeps!
stu if it is a 4wd head case will all the 2wd stuff go in ok!? will it effect compression!?
Old Nov 2, 2005 | 01:26 PM
CraigN's Avatar
CraigN
cams are different
need shims to fit
Old Nov 2, 2005 | 04:08 PM
pugo's Avatar
pugo
Originally Posted by B19-TRB
cheers peeps!
it will if he uses 2wd pistons, it will raise it
Old Nov 3, 2005 | 08:36 AM
B19-TRB's Avatar
B19-TRB
cheers peeps!
thought that was the case!
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
