Running high boost on standard IC, what would happen?
im looking to see why my piston rings have gone pop after 3.5k miles. and was wondering if this had anything to do with it?
i have the standard crap ford IC fitted, but the car is running higher boost then normal, woud this cause them to go pop?? or would this do other damage.
i do have plans to fit a Pro alloy one in the future
Originally Posted by T28 RST
How much boost
whats the max the frod intercooler can take then?
Originally Posted by Tony Turbo
I would say 10psi is the most you can run safely. It really is pants. 14psi is far too much, ACT's will be off the scale by the end of 3rd gear.
Pro Alloy won't be much better either
also what Ic would you recomend if the pro alloy ones not much cop
Air Charge Temp.
The temperature of the air going into the engine. The cooler it is, the better. I had a custom made Pro Alloy one on mine, I have now gone back to a GRS.
but looking at it, i will defo have to get the intercooler sooner rather then later if i want to keep my engine in one piece
Originally Posted by Combi_Chris
14 psi is fine
my 1st rst was running 14 psi on a standard cooler for 2 years
act would defo be off the scale at 14 psi on a standard i/c!! mine was off the scale at just 10.5psi. was'nt much better with a pace double capacity i/c.
GRS now no probs and act NEVER gets above 34 no matter how hard you drive it
probably of the scale but never had nothing in my old one to read act i also sold the car to a friend and it is still going on a standard ic at 14psi and i know at santa pod he wound the boost up more just wouldent hold what he set it to
Ouch
Originally Posted by whiteRSTubby
My front mount pace act's anywhere between 24-28 and I'm running 25psi
Sure your piston rings have failed and you've not actually holed a piston?
CrOwSoN15
18
Aug 22, 2015 10:24 PM
