Skyline gearbox in Sapphire
Hello!
Since I broke my 4wd Cossies gearbox, I have been playing with the thought of putting a Skyline R32 box in the car.
Has anyone got any pics or info of the conversion? Or has anybody done this conversion? What needs to be changed?
I think that at least these parts must be fabricated: cardan shafts, bell housing and clutch? Do I need to make changes to
the transmission tunnel, raise or widen (or both) it? Can I still use the cable clutch or do I have to install hydraulic clutch?
Is it possible to use the ATTESA-system in Sapphire?
Are there any companies that offer parts needed for the conversion? ZOOMotorsport? I'm most interested in finding
the bell housing ready-made. I can make the other parts myself or have them made.
Originally Posted by sierra4x4tbo
Hello!
standard supra boxes are spot on, are used on some mega power cars, not unburstable, but do the job.
pretty much same basic box on the inside as R34GTR 4wd one, and i think M3 6speeder too.
totally different casings mind.
EVO box wouldnt be much good as the engine is transverse on an EVO, cossies are longditudley mounted.
easiest option surely is a Scooby box! longditudley mounted engine, i think the late 6speeders are strong as standard (i may be wrong, cant quite remember), but no matter what, the uprated boxes are mega mega strong, at brunters on monday a scooby was getting some serious serious hammer (60 in 2.6, 100 in 5.6
) and stood up to it no problem, and that was running a 5spd box uprated with PPG dog internals.
Originally Posted by jhw
Originally Posted by wes
The bellhousing Martin supplies is to fit the OSGiken 6speed sequential box, not the std skyline box.
Martin modifies the std skyline box to fit the Ford bolt pattern, he now also produces a cast bellhousing to fit the OSGiken 6 speed box to the ford bolt pattern, this does not fit on the std skyline box.
How does he modify the Pattern.
being as it'd prolly cost a mint to use a skyline box with conversion stuff... why not get intouch with a company like quaife to see if they could put the skyline stuff in a saph box..? just a thought from someone who know's fook all bout g'box's
