xr 4x4 fuel pump run put of puff at 250 bhp?
Old Oct 28, 2005 | 08:16 PM
mrviper's Avatar
mrviper
Default xr 4x4 fuel pump run put of puff at 250 bhp?
been out mapping the car again and went from 14 psi to 17 psi of boost and i have the cosie greens going flat out and the wideband metre was indicating 13:1 afr so i let off the throttle pretty sharpish
note to self std rst radiator is no good for over 230 bhp
if there is people here that can map omex can you tell me if this can happen if the mspb is set too low and not alowing the injectors to work fully ?
also will balest resistors cause a problem with cosie greens?
i'm thinking it's just the fuelpump maxing out
Old Oct 28, 2005 | 08:38 PM
pugo's Avatar
pugo
or a shagged fuel reg
Old Oct 28, 2005 | 09:08 PM
mark's Avatar
mark
it shouldent run out of go on a 4pot at that bhp
tho onr of the guys on interford runs 2pumps on his twin turbo xr4x4
Old Oct 28, 2005 | 09:19 PM
Jim Galbally's Avatar
Jim Galbally
erm, sure your pump aint shagged?
jason_nike
Aug 18, 2019 10:53 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
