goodridge brake hose fitting
Oct 28, 2005 | 04:48 PM
how the fook are you supposed to secure them to the inner wing?
the original (well mine had) uses a spring clip that slots into the groove on the fitting, the replacements dont have this and there isnt enough thread to put washers either side and a nut and still get the brake line on
Oct 28, 2005 | 04:50 PM
should have made your own and used bulkead fittings
longer threads
Oct 28, 2005 | 04:53 PM
That's not the right end then!
That end looks like the caliper fitting.
Oct 28, 2005 | 04:54 PM
i do things the idle twat way pal..........direct replacement
can you buy extension pieces (you know what i mean!) then?
Oct 28, 2005 | 04:56 PM
pon its the flexi hose, goes nowhere near caliper!!!
inner wing to strut
have just made (let tim make) some new lines from strut to caliper
Oct 28, 2005 | 04:57 PM
Front?
SO what the hell goes into your caliper?
Oct 28, 2005 | 05:07 PM
yes front
the copper line does
its where the flexi passes through the inner wing (where the hose meets the line that runs to the abs accumulator) thats the problem
Oct 28, 2005 | 05:09 PM
Oct 28, 2005 | 05:12 PM
shes been stood a while pal
Oct 28, 2005 | 05:14 PM
need a longer threaded fitting
why the hell have you got braided to copper pipe?
Oct 28, 2005 | 05:18 PM
Cable ties will be fine mate.
Dave, usually braided is to replace the rubber pipe so you tell me why it goes like that
Oct 28, 2005 | 05:24 PM
dont get you
the braided hose is a replacement for the rubber flexi hose
what should i have done in your opinion, auroquipped the lot
Oct 29, 2005 | 10:09 AM
Look at the length of the pipe Matt.
From previous experience, the braided pipe often replaces the rubber AND the copper pipe - is it not long enough to do that?
Oct 29, 2005 | 10:21 AM
no pal same length, maybe an inch longer tops
doubt it would allow enough travel in the shocks if i connected it direct
Oct 29, 2005 | 10:30 AM
Then something's not right.
If you get stuck, give me a shout, and I'll sort out the right bits..........
Oct 29, 2005 | 10:35 AM
mine went on dead easy washer on one side and the nut on the other and bobs ya uncle but the end does look a bit small
Oct 29, 2005 | 10:40 AM
It's because it's a caliper fitting - the score in the hex nut denotes a metric thread.
Oct 29, 2005 | 11:02 AM
Pon caliper fittings are either banjo or swivel - that is neither
Oct 29, 2005 | 11:09 AM
i always thought that they replaced the rubber hoses, not the copper
Oct 29, 2005 | 12:08 PM
what the ??
i replaced mine too some while ago and i just screwed
the stainless hoses into both front calipers.
Just put some washers on each side of the inner wing to secure them.
that's what i did and it works just perfect.
Oct 29, 2005 | 12:10 PM
LOL @ copper pipe!!!!BUT its perfectly good as it wont expand like the rubber hose
The Goodridge should replace the lot to the inner wing....just use cable ties to secure it
Oct 29, 2005 | 12:50 PM
only done one side as rain stopped play
will try other one direct to caliper and see if theres enough length
Oct 29, 2005 | 12:52 PM
Oct 29, 2005 | 01:00 PM
you sure using the correct ones? don't mix the front and rears up.
Oct 29, 2005 | 02:02 PM
Quote:
Er, no they're really not
Oct 30, 2005 | 08:30 AM
Matt, I found this pic if it helps on how it should be fitted
steve
Oct 30, 2005 | 09:10 AM
OK mr expert....
How do you screw a solid pipe into a fixed caliper.....
Explain how this is incorrect and and think about it.
Solid i mean fixed both ends btw just so you know
Oct 30, 2005 | 12:48 PM
You screw it into the caliper first and tighten it. You then fit the other end into the mounting bracket and secure it with a nut. Then you screw the swivel fitting on the steel brake pipe to the pipe and tighten. Finally, bleed all the air out.
A lot of standard rubber flexi hoses have no swivel ends either, not just on Fords..
Oct 30, 2005 | 12:52 PM
^^ yep, and when changing calipers etc. you turn them instead. is a pain in the ass tho
Oct 30, 2005 | 01:03 PM
Exactly as would have put it
Care to retract your statement then Dingston?
Oct 31, 2005 | 08:22 AM
i wouldnt have thought the hose was long enough for that steve
will have a look
cheers all
Oct 31, 2005 | 08:27 AM
Matt,
It was supposed to replace the WHOLE thing like in the photo
Oct 31, 2005 | 08:28 AM
aah rears.. me thought fronts
sorted yet laddo?
Oct 31, 2005 | 11:09 AM
sorted
never crossed my mind it would replace both sections
i blame tim for making me lew lines up and confusing matters
Oct 31, 2005 | 11:18 AM
You should have just rang me
Oct 31, 2005 | 11:35 AM
I have just done that job
Bollox attached wrong quote
Meant the bit about aeroquipe ing the whole car
Oct 31, 2005 | 03:59 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
borboyous
Aug 22, 2015 11:17 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
