Fuel pump problem
Old Oct 26, 2005 | 10:28 PM
Mr RS's Avatar
Mr RS
Default Fuel pump problem
the fuel pump was making a very loud constant buzzing and then when tried to start it again it didnt even kick in Ive just put a new turbo on (stage 3 cosworth) could this have caused it by the engine requiring more fuel and therfore burning it out. Checked the relay and this works so im puzzeled to what it can be do I now need a bigger pump, where to get it from and how much. MORE MONEY
Thanks for any help Rob
Old Oct 26, 2005 | 10:32 PM
GrimmeRS2K's Avatar
GrimmeRS2K
normally if they get noisey they are fooked, bridge the fuel pump on constant to check if it is the relay, have u got any fuel in it?
DazC's Avatar
DazC
Even if the relay is clicking, it doesn't mean to say the relay is actually working and it doesn't mean that power is getting to the relay and through it to the pump. Check there is power to pin 30 on the relay and then when it clicks, that power comes out of pin 87.
Old Oct 26, 2005 | 10:36 PM
Mr RS's Avatar
Mr RS
yes fuel in it, will try it tomorrow
cheers
Old Oct 26, 2005 | 10:37 PM
Mr RS's Avatar
Mr RS
swapped the relay from the heated rear screen as thats the same and still not workin
Old Oct 26, 2005 | 10:51 PM
adamS2RST's Avatar
adamS2RST
New pump then!
Old Oct 26, 2005 | 10:57 PM
GrimmeRS2K's Avatar
GrimmeRS2K
check the heated seats fuse, in the fuse box!, and the wires on the pump!
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
