Help! S2 over heating!
Started my S2 last night , to go for a steady run to continue running in the new engine and the temp gauge went sky high and the header tank was making a funny noise like it was gonna blow! Has anyone had this problem before?
sounds to me like a possible air lock in the cooling system although i quote i could be wrong as many people on here seem to want to try and prove me wrong, check it out mate and let us know the reply
try the headgasket, may have had its day.
take the head off and inspect it for anything unusual.
change the head and rocker gasket, and head bolts, all quite cheap Ł30 tops.
or could be air or oil probs, split hoses??
air lock
header cap fucked
new engines always runa bit hotter as they are tight till they slacken off!
good coolant mix?
air lock - take the small hose off the thermo housing and the header cap and leave it running till warm, or till water starts comming out the thermo housing.
rad in good nick, not restricted airflow, fan's kicking in and out?
header cap fucked
good coolant mix?
Yes Engine and turbo are brand new also the rad and all the coolent pipes ! How would u normally get shut of an air lock whats the best method, drain system and start again???
There is a good quallity coolent inside, header tank and cap are also brand new! Fan has been working but failed to kick in last night when it started to expand the header tank. This is what lead me to believe the new thermostat had faild because the fan swithch is the other side of the stat housing?
might be the fan switch??? with the fan not kicking in??? i usually have the fan on a switch to be on the safe side, better safe than sorry as the saying goes, still let us know how you get on anyway mate.
Sounds like a good idea
The fan switch and thermostat are new and the fan is a brand new kenlow!
I shorted the blue multi plug out which controles the fan and it kicked in! An over ride switch is a good idea though think ill sort something out for that at the weekend!
Another thing i noticed which i dont think is right, when u start the car from clap cold the temp gauge needle starts to rise streight away? i could be wrong but i didnt think this was supposed to happen?
Changed the stat , fan switch and coolent but still getting to hot. also fan is still not kicking in with new sensor switch, but it runs fine if u bridge it out? Cant understand it, its as iff the water is not getting to the sensor swithch but the colent pipes are red hot every where?? Surly there cant still be an air lock
Some one told me u can get a different sensor that will bring the fan on earlier than the standard one Is this true
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
cossie09
Sep 10, 2015 06:56 PM
