noise after boost??
Old Oct 22, 2005 | 08:52 PM
Hrsturbo's Avatar
Hrsturbo
Default noise after boost??
When I put my foot down, my car boosts up like normal then when I let off to change gear it makes a funny squeek noise like a shoe on marble floor if you drag your feet??
It squeeks for less than a second but its quite loud. Could this be the hoses??
They are standard hoses running 15psi and feel a bit soft but would this cause a squeek if they are fucked??
Also its losing boost in the higher rev range when its got a new -31 actuator on going to as low as 11psi sometimes??
Sound like fucked turbo, hoses or something else??
Any help appreciated thanks
Old Oct 24, 2005 | 09:38 PM
James Raby's Avatar
James Raby
Proably the turbo flutter as its known, can sound weird sometrimes lol
You won't hold boost on a MFi system, it's not made for it
Only advice I could give is get some silicone hoses anyway, for the price you can get them at it's worth every penny IMO
Old Oct 24, 2005 | 09:40 PM
mark-rst's Avatar
mark-rst
What do you mean by MFi can't hold boost?
Old Oct 24, 2005 | 09:43 PM
James Raby's Avatar
James Raby
Well, say you peak at 1.7bar, it certaily won't hold that all through rev range
You'd need some kind of boost controller
Old Oct 24, 2005 | 10:00 PM
mark-rst's Avatar
mark-rst
ah ok
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
gingeRS
17
Oct 2, 2015 09:42 AM
Russ Payne
Sep 25, 2015 08:29 PM
