knock sensor
Old Oct 20, 2005 | 12:42 AM
russel7.wanadoo.co.uk@fs's Avatar
Default knock sensor
ive tested it with the multi meter and i get no reading is this normal if it is why cant i just disconect it so it dosnt pick up any knocking from the engine
Old Oct 20, 2005 | 08:01 AM
Rallyesport's Avatar
Rallyesport
Just disconnect it. It's rubbish.
Old Oct 20, 2005 | 09:03 AM
davidnormanuk's Avatar
davidnormanuk
I might be wrong but I thought it needed to be connected if the ECU is a series 2 one as it needs to detect the knock sensor to run correctly.
Dave
Old Oct 20, 2005 | 01:46 PM
James Raby's Avatar
James Raby
take the sensor out of inlet manifold and bubble wrap it up then cable tie to something, leave connected
as for saying disconnect it - it's rubbish, typical i heard it on passionford so must be true speak
dont disconnect anything unless advised to by a tuner or YOUR tuner
Old Oct 20, 2005 | 02:05 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Mind block the hole up, someone said you dont need too but i checked with a screwdriver and it went right the way in
Old Oct 20, 2005 | 03:24 PM
yes i have a spare one to block up the hole
will the unscrewed one in buble wrap need to be earthed? ill try it anyway
Old Oct 21, 2005 | 12:11 PM
JesseT's Avatar
JesseT
How on earth do you check a knock sensor with a multimeter?
Old Oct 21, 2005 | 02:27 PM
vroooom ptssssh
It Wasnt Me!
get someone to tap on the inlet with a spanner and check for current
Old Oct 22, 2005 | 06:59 AM
Rick's Avatar
Rick
pmsl.
Unfortunetly it's not that simple.
And you can't disconnect it, as ur car WILL run like a sack of shit.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
