S1 owners! What RPM in fifth on standard wheels @70mph
Old Oct 16, 2005 | 10:18 AM
AD-RS1600i's Avatar
AD-RS1600i
Default S1 owners! What RPM in fifth on standard wheels @70mph
Quick one for the S1 owners,
Very scientific bit of research this!
My RS1600i at 70mph is reading about 3k on the clock, I know my S2 at 3k was indicating just under 90mph, so was wondering what a S1 reads at 3k?
On standard 15" wheels please
Old Oct 16, 2005 | 10:30 AM
essexrsturbo's Avatar
essexrsturbo
hmmm... thats weird because both my last S2's used to cruise in 5th on a standard LSD box at 70mph at 3k.
have driven my S1 yet as it still being built so could say
Old Oct 16, 2005 | 10:32 AM
Stu.H's Avatar
Stu.H
S1 owners! What RPM at 3k in fifth on standard wheels
id say u'll be doin about 3000rpm mate
Old Oct 16, 2005 | 10:37 AM
Oranoco's Avatar
Oranoco
Beat me to it
Old Oct 16, 2005 | 10:39 AM
essexrsturbo
did you ever drive yours on 15's oranoco?
Old Oct 16, 2005 | 11:34 AM
DazC's Avatar
DazC
Dunno if it helps but on 15" standard rims, standard box my S1 was doing 70mph at 3700rpm....
Now on S2 ratios ond 16" wheels so can't compare for you either. 70 is rouughly 3100rpm ish though.
Old Oct 16, 2005 | 03:32 PM
AD-RS1600i's Avatar
AD-RS1600i
Beat me to it
pmsl just checking to make sure you lot are awake!!
that's really wierd, like I say my S2 at 3k was doing just under 90mph and my RSi was traveling at roughly 70mph at 3k .....
I was looking for a half way house, for cruising.
Old Oct 16, 2005 | 03:36 PM
Dan's Avatar
Dan
Beat me to it
and me!
Old Oct 16, 2005 | 03:43 PM
DazC's Avatar
DazC
My old Orion 1.6 I Ghia was doing 2600rpm at 70. At 3k it will be about 80...
Old Oct 16, 2005 | 03:53 PM
AD-RS1600i's Avatar
AD-RS1600i
This is bizarre, i've always thought the RS1600i had the revvyest gearbox between itself, a XR3i and a S1. But looking on the net, assuming the data is correct, it isn't alot different to a S2 box?
RS1600i Final drive
3,84:1 final drive ratio.
S1 RST Final drive
4,27:1 final drive ratio.
s2 RS Turbo Final
3.81:1
Is this right cheers
Old Oct 16, 2005 | 10:35 PM
AD-RS1600i's Avatar
AD-RS1600i
bttt
Thought you lot were supposed to know everything about everything!
Old Oct 17, 2005 | 11:29 AM
DazC's Avatar
DazC
Originally Posted by AD-RS1600i
bttt
Look for the ratios on the Mk 1 Orion 16i ghia.....
Old Oct 17, 2005 | 11:56 AM
Thrush's Avatar
Thrush
Irritating c........
Both my S1's read 3k or thee abouts at 70mph, tho my 3i (mk4) red a tad under 3k at 80mph...
Old Oct 17, 2005 | 12:18 PM
AD-RS1600i's Avatar
AD-RS1600i
That sounds about right
I think both the S1 and the RSi must have roughly the same gearing in top
Your 3i sounds like it had the same gearing as my S2 (which over read because it was on larger than 195 tyres)
Thanks for the information
Old Oct 17, 2005 | 01:04 PM
DazC's Avatar
DazC
No because a STANDARD S1 box with STANDARD S1 ratios will give around 70 MPH at 3700 rpm....like I said earlier. My car was nigh upon TOTALLY standard and origional when I bought it.
Thrushes cars won't have had the standard spec origional gearboxes in them if they where only doing 3k at 70...
Old Oct 17, 2005 | 01:51 PM
Thrush's Avatar
Thrush
They were standard boxes Daz, chances are then that the speedo or rev couter was out...
Old Oct 17, 2005 | 01:59 PM
DazC's Avatar
DazC
Possibly Thrush. I know mine where spot on.
Old Oct 17, 2005 | 03:55 PM
AD-RS1600i's Avatar
AD-RS1600i
3700 @70mph would tie up with the ratios quoted above I suppose, still don't get it though, A) that a RSi has a longer final drive than a s1 b) my RSi box is supposed to be a similar final drive to a S2
Explains why when people compare S1 and S2 turbos, they'd say S1 isn't as good dailey driver, not suprised with that gearing!
Old Oct 17, 2005 | 05:39 PM
Thrush's Avatar
Thrush
Thats right Ad - the S1's I found to be a pain on the motorway as you drive along at about 90/100 and it's screaming it's nuts off at about 4-4300 (can't quite remember - been a few years) 120 is over 5k IIRC, never had it to 140 tho
The 3i was better for motorway driving, my mates S2 was better still.....
Old Oct 17, 2005 | 06:21 PM
S1 JOHN's Avatar
S1 JOHN
so its not just me that thinks the ratios are shite then the gears dont last 2 mins in my series 1
Old Oct 17, 2005 | 06:25 PM
DazC's Avatar
DazC
That's why mine now has S2 gear ratios John.
It used to really spin the wheels when it was on S1 ratios.
Old Oct 17, 2005 | 07:36 PM
AD-RS1600i's Avatar
AD-RS1600i
3700 @70mph isn't practical, and with a powerful S1 your just gonna whip through the gears in no time.....this probably wouldn't have been a problem in a standard car, and the box was probably geared like that for rallying ...................this is probably why most the S1 i see on the road are pottering around the 65-70 mark lol
Still can't believe the RSI box is taller There goes my master plan for a cheap reliable LSD box, that would fit minimal effort...
I really like the S2 box, i think at 80+mph your doing about 3k dead on, you can cruise all day with that
Bit too steep for a n/a RSi though, will make it feel slow should refraise that, 'feel slow to me' ! good fun though
Thanks for the input
Old Oct 17, 2005 | 07:50 PM
dry's Avatar
dry
At 0 mph mine does anywhere between 0k rpm and 6k rpm cos my speedo don't work at the moment ! Hope this helps
Red_bull
Aug 25, 2015 06:27 PM
borboyous
Aug 22, 2015 11:17 AM
RSMK4TURBO
Aug 19, 2015 04:46 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
bassboy
Aug 8, 2015 10:21 AM
