ian howell 2.1 zvh bottom end!
Old Oct 15, 2005 | 08:46 PM
Davey8oy's Avatar
Davey8oy
Default ian howell 2.1 zvh bottom end!
Alright peeps! time to pull my finger out my arse and post my lump up for sale!
its a ian howell/area 6 built bottom end! done about 7k! cost £2 grand!
its been bored to 86 mm using ians spec pistons! vauxhall calibre i think! arp rod bolts! fully lightened and balanced. comes with newly fitted water pump! this block was brand new when brought for the conversion!
also comes with modded cam belt tensioner, water pump and coversion plate fitted, modded 1800 zetec sump, every thing apart from a flywheel!
Now for the bad bit! due to a local tuner the engine suffered det! causing slight pitting to no 3 cyl! i ve had two independant machine shops check and they have told me the bores are fine! all it will require is a piston if ya tight or a set and the bores honed! ian has quoted me £240 for a set of pistons and it will cost £70 to have honed and have the pistons fitted! im not going to do it cos i ve moved on and brought a new zvh with all steel bottom end in the seek for more power and revs!
the engine did and will still make up to 300 bhp with a new set of pistons and correctly set up engine management!
all yours for £500 ono
Old Oct 16, 2005 | 05:01 PM
P_is_for_Paul's Avatar
P_is_for_Paul
Coldo loves seamen
Does this bolt straight onto cvh head? Take it i would need to fit efi?
Old Oct 16, 2005 | 07:46 PM
Davey8oy's Avatar
Davey8oy
s1_turbo
it will except a cvh head! to have it 100% perfect you ll need a bit of alloy welded to the rear of your cyl head to allow more surface ares to press against the head gasket!
you can run k jetronic! it was runnin it on mine till i changed to cossy only for the chatter lol!
Old Oct 17, 2005 | 02:24 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Very interested - what rods is it running?
Old Oct 17, 2005 | 05:53 PM
Davey8oy's Avatar
Davey8oy
standard zetec rods with arp rod bolts all lightened and balanced!
Old Oct 17, 2005 | 06:01 PM
Lee @ Fusion's Avatar
Lee @ Fusion
Thats a cheep botom end ,
machining alone coss around £400 ,
If u look on mig web you can pick up a set of second hand calibra pistons for £100-150
good luck with the sale bud
Old Oct 17, 2005 | 06:07 PM
Davey8oy's Avatar
Davey8oy
Lee @ Fusion
cheers mate! the new lump im havin i could nt refuse cos i got em at a steal! but would like to keep it! but its got to go!
Old Oct 19, 2005 | 06:58 PM
Davey8oy's Avatar
Davey8oy
Old Oct 20, 2005 | 11:01 PM
TONY C's Avatar
TONY C
wheres Canvey Island?
Old Oct 21, 2005 | 06:59 AM
Davey8oy's Avatar
Davey8oy
TONY C
essex! southend!
Old Oct 21, 2005 | 02:55 PM
rich p xr2t's Avatar
rich p xr2t
DONT 4GET UR PASSPORT
Old Oct 21, 2005 | 04:38 PM
Davey8oy's Avatar
Davey8oy
rich p xr2t
fook off! cock boy
Old Oct 26, 2005 | 10:30 PM
Davey8oy's Avatar
Davey8oy
on ebay now!
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
