NONE starting Cossie
Old Oct 12, 2005 | 07:11 AM
Alvyn's Avatar
Alvyn
Default NONE starting Cossie
was running fine prior to what EVERS gone down this time(felt as though the fuel switch in the boot had been activated but it hasn't as the pump is still primeing etc) BUT the injectors are NOT pulsing while engine is being cranked over!
n e suggestions as to what sensor if n e it could be.
Old Oct 12, 2005 | 07:25 AM
Disabled Account's Avatar
Disabled Account
Check the crank sensor first - look for dirt or oil on the sensor face.
Old Oct 14, 2005 | 01:05 PM
Alvyn's Avatar
Alvyn
will have a check to see over the w/end HOPEFULLY
Old Oct 14, 2005 | 01:13 PM
Graceland's Avatar
Graceland
Team HOTHOT!
crank sensor and then phase sensor - defintaely an engine speed sensor thats failed if you are getting no injection pulses.
my moneys on the phase sensor - dunno why tho, it just sounds promising
Old Oct 14, 2005 | 01:18 PM
DazC's Avatar
DazC
Odd, have a look at the phase sensor...
The ECU deffinately KNOWS the engine is turning over because the fuel pump is running on cranking.
Old Oct 14, 2005 | 01:20 PM
Petrucci's Avatar
Petrucci
i had this exact problem one year ago, and it was a shitty CTS.
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Alun Gregory
Sep 6, 2015 09:40 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
