Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Capri zetec conversion engine mounts particularly
Old Oct 11, 2005 | 10:20 PM
Griffo's Avatar
Griffo
Default Capri zetec conversion engine mounts particularly
ive got a few questions that have been left un answered about the conversion besides that information is openly available from old skool escort conversions
what do you do about relocating the breaks? can you just use the pedal boxes for the mk2 escort?
dos it still need the thermostat housing changing?
will a 1.8 cvh sump foul the steering rack without work?
ive been searching high and low for some engine mounts and they dont seem to be out there. are there any that are easy to modify to accomodate the zetec? posibly the pinto mounts? (this is my most diar queston as i can use trial and error on others)
p.s. please dont give me a link just to go and ask on another site ive probably already looked
Old Oct 13, 2005 | 07:32 PM
alladdin's Avatar
alladdin
mounts, the escort ones for zetec from retro ford will probably fit even if you have to adjust rubber thickness(phone dave). or slice off tops of crossmember and make some chassis mounts.
sump...im not sure, it needs mods for escort fittment so probably will for capri,why worry just cut@n@shut it. you can put a wing in at same time.
water rail needs moving to fit in escort. check your rear clearance against a mk2..... if you got more it might fit but id guess they are similar, the crappy has got all the space at the front !
hope this helps a little.
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
