Cossie rocker cover gasket
New gasket, some gasket sticky stuff for the half moon seals (hylomar I think it's called - someone will correct if wrong
) and the cam shaft half moon seals x2.
Cometic rocker cover gasket is possibly a better bet than the Ford OEM one, imo.
) and the cam shaft half moon seals x2.Cometic rocker cover gasket is possibly a better bet than the Ford OEM one, imo.
piece of piss and you need a gasket and 2 half moons seals.
Just tighten the allen key bolts up like you do a cylinder head, criss cross type of thing.
Be worth while buying new allen key bolts for the rocker cover.
Ive done them without any sealer on mine and not had a problem at all, to be honest i cant imagine why they would need sealer when they are under compression, but i guess if you dont clean the surfaces you might need it, and its certainly not going to cause any harm if you do use it.
Takes about an hour to do the job, but half that time is cleaning the surfaces.
Use a cometic gasket, well worth the extra few quid.
too much and it may go into the oil,into the sump and block the pick up pipe, seen lots of sealer on that!
Originally Posted by KSA-Cossie
dave cos4x4, ok m8 thanks for all the replies troops,i want to change my bogging green one for a nice blue one lol.
Sean,
think he is on about changing the rocker cover which then needs a new gasket putting on.
Chip...there are people out there.
Ditto Dave, have also used PJ, MSD, GGR & R&B for parts - all with no hassles, and very prompt service.
www.grahamgoode.com
www.RandBMotorsport.co.uk - parts not listed, but Mike can get most things
www.remapping.co.uk - MSD (STU@MSD off here)
http://www.pjmotorsport.com/vehicles...=sapp4wdenggas
http://cosworth.info/store/ Woodford
HTH
Bill
www.grahamgoode.com
HTH
Bill
Indyrs
Dec 4, 2022 12:39 PM
