*SOLD* Esc Cos Full Kit Of Parts - Great Project
Old Oct 11, 2005 | 03:43 PM
TwoCossieBob's Avatar
TwoCossieBob
Default *SOLD* Esc Cos Full Kit Of Parts - Great Project
I have a full set of Escort Cosworth parts to build a very competitive race or track car. Parts are not assembled and thus work is required to build the car but almost everything required is available, see the list below...
Escort Cosworth motorsport bodyshell wilth full GRP N cage. This shell is absolutely mint and I do mean mint, you will not find a better one! All panels and floor are straight. The shell has just had a complete external diamond white low bake professional respray at a total cost of over £1500. The underside is freshly coated in black hammerite. Do not confuse this shell with others that have just been stripped or have been lying around for sometime!
A1 Rallysport engine complete with all bolt on items and ECU required to run it. Low comp with grey injectors, BD cams and lightly ported head. Only done about 6000m since full £3000 rebuild by A1 Rallysport, produced 420bhp on first run and 80% boost. You all know how good the A1 engines are!
MT75 4x4 GRP N gearbox with Quaife internals and built by DOME. This gearbox is essential for high power 4wd cars. The gearkit costs £3750+vat from Quaife!
New T34 turbo.
New genuine bonnet, bonnet vents and side skirts.
All shell glass and door trims/seals, all fitted.
Carbon type/look door cards and rear quarter covers, all fitted.
Replicar rear spoilers and front grille, all fitted.
Mint doors and tailgate, all fitted.
Front & rear replica bumpers.
GRP A breather system with mirror type header tank.
Remainder of fluid tanks, all alloy.
Stainless big bore exhaust system.
Wiper motor and arms assembly.
Vibratech engine mounts.
Full car set of blue Samco hoses.
Mocal remote oil fitler and oil cooler/radiator system.
GRP A mega sized cone filter and shield.
Pair of Sparco Carbon Pro bucket seats, cost over £750 each.
Pair of TRS 3" five point harnesses.
Power steering rack and assembly.
Front Crossmember.
Front compression struts and adjustable tca's.
GRP A type front anti rollbar
AP315 4pot rear brake kit complet with used but good pads.
AP355 6pot front brake kit with new pads.
Front Diff and mounting brackets.
XR4x4 front driveshafts (stops failure of shorter cosworth ones).
Front & rear hubs.
Rear driveshafts to suit 7.5" rear diff.
Car set of AVO coilovers.
Car set of tarmac rated coilsprings.
GRP A 7.5" adjustable rose jointed steel rear beam and arms, mint.
GRP A front top mounts with pivot bearing.
AP 4 paddle clutch and cover
Pectel full car loom, aircraft quality, very rare!
Full set of rally car instrumentation all wired and assembled on loom.
Carbon dash/instrument panels, instruments pre mounted.
Dashboard with brand new flocking, absolutely mint!
Premier bag type fuel tank, 60 litre capacity with swirl pot, mounted in car.
Carbon cover and sender unit for bag tank.
GRP A fuel pump and filter system, all jic fittings etc.
Full set of fuel lines, run internally in shell.
Full set of aeroquip brake lines, run internally in shell.
Morette twin headlight kit and bulbs, rear lights.
Car set of GRP A Compomotive 6 spokes, 18x8 with correct offset.
Car set of new Pirelli intermediates, 225/650/18.
Hydraulic handbrake, fitted.
GRP A twin cylinder pedal box with adjustable bias.
New 4kg Lifeline fire extinguisher system and all pipes/nozzles.
Door mirrors, locks and keys, all fitted.
New RS500 type intercooler.
Radiator and fans.
Power steering oil cooler system and all hoses.
Clutch and throttle cables.
GRP A coil.
Front & rear propshafts.
Steering coloum and Momo steering wheel.
Turbo heatshield.
Pair of seat runners and fixing brackets.
Needs a rear diff!
Various other odds and ends!
Most bolts/nuts and mounting brackets for all of above!
Also avaliable is a current Swansea registered V5 ID to go with the above parts. ID is for a 2.0 litre Ford Escort 3DR Saloon in white, its not a cosworth one but could be used with the above car with out any problems. Floor stamping and under bonnet tags are available, the V5 is in my name.
I am looking to sell all of the items as a complete job lot to give someone the opportunity to build a great competitive race or track car.
My guide price is £10,000 plus, the best offer or even the quickest decent offer over £10,000 gets the whole lot!
I am located in Newbury, Berkshire.
I can deliver the shell for a petrol contribution but you will need a van to collect all the other parts.
Thanks
Bob
Old Oct 11, 2005 | 05:18 PM
jbrayley's Avatar
jbrayley
Would you consider selling the parts seperately? I would be very interested in the front brakes
Old Oct 12, 2005 | 08:31 AM
TwoCossieBob
Hi
I am getting lots of messages about seling inividual parts but I don't have the time to do this at the moment as I am working away in Ireland. If I did sell the parts individually then I guess they would fetch closer to £20k than £10k. This is a great opportunity for someone with the time to build the car or just take the parts and sell the ones they don't want to get their £10k back.
Thanks
Bob
Old Oct 12, 2005 | 05:45 PM
Tony Ryan's Avatar
Tony Ryan
Hi Bob,
You have mail mate , give me a bell when youve a sec.
cheers
Tony
Old Oct 16, 2005 | 01:50 PM
TwoCossieBob
Default Esc Cos Race/Track - Complete Car But In Parts *PICS ADDED*
Pics Added.
Old Nov 10, 2005 | 06:37 PM
Lee Fordham's Avatar
Lee Fordham
Hi,
Would you sell the Group A roll bar pls? Would it fit a sapphire 4x4?
Do you also have a 22mm rear arb??
Thanks
Lee
Old Nov 16, 2005 | 01:42 PM
Porkie's Avatar
Porkie
FOOKING BARGAIN!
Old Nov 16, 2005 | 03:39 PM
Mr RS500's Avatar
Mr RS500
Is this still for sale ????
Old Nov 16, 2005 | 04:46 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Pete,
I think this was sold and is now in bits on eBay, a very similar shell was for sale on there, so similar in fact that I recon the description was a copy/paste job.
carlo
24
Oct 5, 2015 08:20 PM
Aug 17, 2015 09:06 PM
Aug 12, 2015 10:03 PM
Aug 12, 2015 09:35 PM
Bart
Aug 9, 2015 09:04 AM
