how to use a pf09 TPS on a 2wd L6 ECU ??
Old Jul 5, 2004 | 11:51 AM
kennert's Avatar
kennert
Default how to use a pf09 TPS on a 2wd L6 ECU ??
As above, can I just switch around the two outer wires in the plug of the TPS and use the new pf09 TPS (mind you it's an L6 ECU 2wd saff).
Cheers Kennert
Old Jul 5, 2004 | 11:52 AM
Stu @ M Developments's Avatar
PassionFords Creator
No,
To do it properly and activate overun fuel shutoff and idle strategies correctly requires a PF01.
Old Jul 5, 2004 | 11:53 AM
turbinator's Avatar
turbinator
Default Re: how to use a pf09 TPS on a 2wd L6 ECU ??
Cheers Kennert
no ... if youre car is 2wd.. and you run an L6.. there should be a PF01 in place.. not a pf09 .. only when running a L8 or P8 you should change to PF09 ..
Old Jul 5, 2004 | 11:59 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yeah but what engine loom do you have? 2wd or 4x4?
if you started with a 4x4 loom with the pf09 tps and you are now wanting to change to a L6 ecu for some reason, you'll need the pf01 tps and you'll need to swap the outer wires around.
if you have the 2wd loom, you'll still need the pf01 tps
Old Jul 5, 2004 | 12:02 PM
kennert's Avatar
kennert
thanks guys.
It's a 2wd loom, L6, everything is 2wd!
I've found a pf09 on ebay that was at an ok price, but I'll stick to pf01 then.
DixieTheKid
11
Jun 6, 2020 11:20 AM
mark r
Sep 29, 2015 07:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
DixieTheKid
Sep 14, 2015 09:04 PM
