Anyone know what a standard M3(E36) will top out at with....
Old Oct 10, 2005 | 02:50 PM
Mr Brannen's Avatar
Mr Brannen
Default Anyone know what a standard M3(E36) will top out at with....
a Chip to de - restrict it.
Just wanna know if its worth getting it done ,
I`ve heard some say 160, 180 , but the bloke at Superchips reckons 175mph, anyone shed some light please
Thanks Mr Brannen
Old Oct 10, 2005 | 02:51 PM
Stealth Bomber's Avatar
Stealth Bomber
175 sounds a bit optimistic, but surely can't be far off, they got over 300bhp right?
Old Oct 10, 2005 | 02:52 PM
Mr Brannen's Avatar
Mr Brannen
will have with a chip mate, 320bhp according to Superchips
Old Oct 10, 2005 | 02:53 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
With the wind behind it , then yes theoretically it could reach 175mph if it had the power to pull the gearing....
I would say that it would need the exhaust and filter mods along with the chip to get anywhere near that though and a VERY long stretch of road .
Old Oct 10, 2005 | 02:58 PM
Mr Brannen's Avatar
Mr Brannen
I know Mike but I been in my mates when he was on the limiter at 155mph and I saw how easily it made that
Old Oct 10, 2005 | 03:01 PM
Mike Rainbird
Caraholic
A 350bhp Cossie also hits 155mph easy as pie, but after that, especially at 170mph, each mph requires a LOT of extra power, as wind resistance builds up exponentially.... It takes 400bhp to hit 170mph in a Sapphire (at Brunters).
Old Oct 10, 2005 | 03:03 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Also about gearing and what rpm the power is though.
A T4d 400bhp Cossie on a std gearing will do it easier than a T34d one just cause of the power being higher up, a genuine 170mph in a cossie is v.high rpm...
Old Oct 10, 2005 | 03:04 PM
Mr Brannen's Avatar
Mr Brannen
M3`s are geared better than Saphs for top end though Mike , am I right?
R4N SS's Avatar
R4N SS
im sure E36 M3s are close to about 280bhp.
M3 Evos are 321bhp and have more chance of getting to the figures quoted but as mike says will need a VERY long stretch of road to do that.
Old Oct 10, 2005 | 03:07 PM
Mr Brannen's Avatar
Mr Brannen
Yeah but Superchips reckon a chipped M3 will be what a standard Evo M3 is, Surely they will know better than most what figures you can expect from any car .
Old Oct 10, 2005 | 03:09 PM
Mr Brannen's Avatar
Mr Brannen
I didnt ask "how big a stretch of road would it take for a ........" I simply asked " Can it do it..."
Old Oct 10, 2005 | 03:10 PM
Mike Rainbird
Caraholic
If it is a 3 litre one, then I doubt it would get to 175mph, but if you can give me the final drive, fifth gear and tyre sizes, I will tell you what revs it would need to do to achieve this. I thought that you meant an Evo version, as you mentioned 320bhp and once chipped, these can get to 350ish with exhaust and filter mods...
Old Oct 10, 2005 | 03:12 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Evo's are also 6 speed
Old Oct 10, 2005 | 03:24 PM
Mike Rainbird
Caraholic
Just done a quick search and the 3 litre cars have a 22.7mph / 1000rpm top gear, which means that it would have to reach 7,700rpm in fifth to hit 175mph. I would imagine that this would be a little too far past peak power of the 3 litre car, even in tuned form (as standard they are rev limited to 7300), and would say that 165mph would be more realistic, unless the rev limit is raised or gearing altered with bigger rear tyres .
Old Oct 10, 2005 | 03:26 PM
rsdene's Avatar
rsdene
i've been in a standard one @ 162 of the limiter in sixth
Old Oct 10, 2005 | 03:27 PM
Stealth Bomber
At an indicated 162...
Old Oct 10, 2005 | 03:30 PM
rsdene's Avatar
rsdene
well in the m3 i was in if you pressed the trip computer it would read out speed. so when it was on the limiter we pressed the button and it said 162.
Old Oct 10, 2005 | 03:39 PM
Mr Brannen's Avatar
Mr Brannen
Thanks Mike , but he did say that the chip raised the Rev limiter, but thanks for checking it out for me anyway
Old Oct 10, 2005 | 03:51 PM
Dan's Avatar
Dan
Was gonna say that people reckon they have had these reading 180mph on the speedo, but obviously this was probably pub talk!
Would agree that the EVO version would be better suited to higher speeds acheived.
Old Oct 10, 2005 | 04:00 PM
Mr Brannen's Avatar
Mr Brannen
only have 160 on the speedo
Old Oct 10, 2005 | 04:09 PM
Andy-R's Avatar
Andy-R
Peak power is around the 6700rpm mark from memory, which when multiplied by Mikes 22.7 per 1000 gives a figure not to distant from the limited 155mph.
Assuming that the rev limiter were to be removed, I still recon it would take a fair bit to hit 170 let alone 180.
Old Oct 11, 2005 | 12:02 PM
WD Pro's Avatar
WD Pro
I can only comment on the evo (3.2) but mine did this in fifth :
No idea what the speedo said and it didn’t hit the limiter or the shift light didn’t come on, got their quite quick to, only wish I had looked at the clocks as it should have been well off the scale …
Derestricted, ACS (who I think can be trusted) quote 282 kph (175.2 mph) Only mod they do on this spec is the delimiter module (about the size of a match box i.e. not a chip or remap) and exhaust.
WD
Old Oct 11, 2005 | 12:07 PM
Adam_BlackRS
Ex Ford Man
M3's are up to 170 on there speedo's
Old Oct 11, 2005 | 12:13 PM
WD Pro's Avatar
WD Pro
Both right ! :
Words = 160
Scale = 170
Old Oct 11, 2005 | 12:17 PM
b3nle's Avatar
b3nle
my e46 m3 coupe has 185 on the clock. FYI, It races round to 168 ish then limits back when i change to 6th
Old Oct 11, 2005 | 01:36 PM
Mr Brannen's Avatar
Mr Brannen
yep but that aint an e36 realy is it
Old Oct 11, 2005 | 03:47 PM
b3nle's Avatar
b3nle
As i say FYI.
Old Oct 11, 2005 | 03:48 PM
Mr Brannen's Avatar
Mr Brannen
Thanks
Old Oct 11, 2005 | 03:52 PM
b3nle's Avatar
b3nle
thats ok
Old Oct 11, 2005 | 04:01 PM
Mr Brannen's Avatar
Mr Brannen
Well sod off then you Bearded Piss Flap
Old Oct 11, 2005 | 04:04 PM
b3nle's Avatar
b3nle
suck my balls, buy a newer car cOck
Old Oct 11, 2005 | 04:10 PM
Mr Brannen's Avatar
Mr Brannen
Fuck off you snob, ya on a Cosworth web site the most recent Cosworth being made almost 10 years ago,
Old Oct 11, 2005 | 04:12 PM
b3nle's Avatar
b3nle
its not a cosworth site dickhead.
Old Oct 11, 2005 | 04:41 PM
rapidcossie's Avatar
rapidcossie
had my non evo m3 at 165 on the speedo......
James Porter
Oct 28, 2015 12:17 PM
TrevCos
Aug 17, 2015 09:08 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
