anyone use a wireless video sender?
you know when u wanna watch Sky TV from downstairs on a TV in the bedroom? Any reccomendations?
Also do they include passthroughs that allows you to keep the the unit connected to your tv downstairs?
Yes you can keep the TV downstairs connected.
Do you have WiFi in the house? You may get interference with that - if you get problems try shutting that off to prove it, then try different channels on the TV sender.
got one from ebay - works fine & has a resender thingy for the tv remote aswell, about £25 all in i think, sure there is better quality ones out there though, plenty on ebay, philips ones are good, depends on how many walls they have 2 go thru!! & mine hates the microwave being on
I got a cheapo one from Maplins a while ago. It works fine including the remote control but you will need to fiddle about with channels if you have wifi. Microwaves do interfere with the signal too.
James
James
