Pectel Loom.. fuel pump feed not working?
Old Oct 10, 2005 | 10:15 AM
DaveEscos's Avatar
DaveEscos
Default Pectel Loom.. fuel pump feed not working?
Fired up the new engine lastnight... started fine! IF i gave the pump a feed from the batt or other source (temp measure) because..
the fuel pump feed from the pectel loom isnt going live on ign on, or cranking???
any one know why? or hazard a guess?
Loom has a perm feed, ign feed and an earth
car idles fine when pump is given a feed, so loom and ECU are fine
just the fuel pump feed not going live?
there are 3 relays on the loom. all brand new and seem to be clicking ok
any ideas ?
Old Oct 10, 2005 | 10:24 AM
Stu @ M Developments's Avatar
PassionFords Creator
Quickly call Ahmed and ask him to check that the fuel pump trigger is enabled in the ECU software he gave you Dave. That may save some time if theres been a tiny oversight at ecu level.
Old Oct 10, 2005 | 10:29 AM
DaveEscos's Avatar
DaveEscos
stu.. very nearly spot on!
I run a motorsport spec pectel board and ALS board.. so this doesnt enable fuel pumps..
i need to run an earth to Pin 28
Ill test to see.. but Ithink thats the cause.
so close matey!
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
